SOURCE: BOOTA ERROR! NEED HELP! SONY DESKTOP VGC-RB52
Hi i'm Rain .
You were requesting a video on ram. { Click here }.
If you need further assistance please feel free to contact me.
SOURCE: sony vaio vgc rb52 no sound ... speakers work
Hello there... Check your PC's volume. You may or someone in your household has accidentally muted it. Unmute it or increase its volume (if you can't find the audio icon in the taskbar, proceed to the control panel - it's there), it maybe too low. Hope this helps... Ai :)
SOURCE: how do i connect my sony desktop model vgc rb52 to
You must purchase an adapter that converts USB to a VGA Port. That is the only way!! Tigerdirect.com has them fairly cheap. I know of this because I did this exact thing and it works perfectly for me going on two years now!! Try It You Can Always Return in 30 Days @ Tigerdirect.com
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: I want to switch it my monitor from HD15 Mode to
Assuming you have not already upgraded the system, you will need to add a video card with DVI output to your computer. You need a PCI-e x16 card and to make sure to either upgrade your power supply or choose a card that will not exceed the power supply's capacity. The original Power supply provided 305W (max.).
The alternative is to simply attach a DVI to VGA converter and stick with the on-board VGA only output but send it through the DVI port on the monitor.
I hope this helps.
(you should pay attention to heat issues if you add a video card; I've generally found that ATI cards run a bit cooler than nVidia cards for the same generation/performance.)
SOURCE: how come my sony vaio vgc-rb52 desktop goes on but
if you are referring to the signal strength of your wireless internet, first try to turn off both devices your laptop and your wireless modem or router. Now if you have a portable usb broadband connection and the signal is showing weak or no signal at all call your internet provider so they can check if they have any server issues.
