Did you turn engine over coupla times to completely drain bike whilst emptying with drain plug out and lid off tank? If not you run risk of partial retainment in oil cooler and engine. While refilling it pays to half fill then turn engine over few times to flush oil through before topping off. How much oil came out when you drained? Yes, your bike should take about 3 1/4 Litres to fill from completely drained.
Dealer's usually tell you the amount you need if the bike is completely empty. Take a turkey baster and remove some oil, ride the bike and check the oil level again. I have seen to much oil blow the dip stick out and cover everything with oil and I have seen the oil tank split.
