its a Rockford fosgate RF2002 it wont push any power to speakers and has a blinking orange light that comes on and then it will blow the fuse ?its a Rockford fosgate RF2002 it wont push any power to speakers and has a blinking orange light that comes on and then it will blow the fuse ?
You can't post conmments that contain an email address.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Hello Ejaz,
You will also probably need to change the blown fuse for the lamp also located near the lamp. The blinking orange led is just showing that the circuitry cannot sense any light output yet!
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Let's just assume that your a/c system had no leaks, and the refrigerant (should be R134a and not freon) charge still complete. Automatic hvac controls uses push buttons instead of the manual rotary knobs. Once you push a button for a particular function, the corresponding light will indicate on. Normally the light should turn on steadily once requested and enabled. If that light is blinking, it is just telling that the function you requested is not yet available at the moment, even if you pressed it repeatedly. Why? It's because the engine control module (ECM) senses that some conditions are not yet in place and he wont allow it. Thats part of its programming: efficiency and protection as well. It will allow later when it senses evrythings okay. However if this blinking goes on all day, then you need to have your truck checked thoroughly, specially by scanner. Double check for leaks, too. Goodluck, and have a nice day. : )
All Nintendos do this... just blow on the game cartridge and inside the door really hard. Make sure the game is fully inserted and pushed down then try it.
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
