*First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote:
HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Services\EventLog\Application\Oracle.oracle
* Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are
running then disable it. Then find and delete the services entry from
registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
http://psoug.org/ PSOUG.org is an Oracle community resource dedicated to supporting users and developers of the Oracle database.
lots of great code samples. http://www.iselfschooling.com/ offers free training. It's a great site for new users / dbas
This is an Error generated by the Oracle Client when the Oracle Server can not
be reached.
This error can be caused by several items:
The
Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator The
network connection to the Oracle server is not fully up and running. Check all
connection points between the Notes server and the Oracle Server A firewall
exists between the Notes Server and the Oracle Server, and is not configured to
allow access to both the Oracle Server's IP address and Port The ADDRESS
Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on
Oracle 8.0.x) to check the connection to the Oracle Server. Example of a
successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping
Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on
23-APR-99 10:24:39
Attempting to contact
(ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521)) OK (50 msec)
If
this is Not successful, check your Oracle Network Products Messages Manual to
resolve the errors that TNSPING points out.
well i found this from one
site .... hope u can read it and can solve your problem
registry:
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
