Check your laptop for a speaker icon on one of your keys, mine is on the Esc key, once found press the Fn key and hold, now press the key that the speaker icon is on and sound should be restored.
Goto Start-> Settings-> Control Panel click on sound and audio devices.Click on advanced button under device volume. On the popup control click on options properties and click on recording if you cannot access that select the drop down above and click on input and then click on ok. Un mute the mic and if you have a recording volume slider , set it to the level you want. Now test by speaking into your mic and set recording volume.
You have a laptop and it has a built in mic You need to nominate your webcam mic as default
TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Its important to set your webcam mic as default (the one you want to use) especially if you have a laptop with a built in mic as well
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders (adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
First check you dont have a red line through your speaker on your toolbar. If so click it and "UN-mute it.
If using external speakers then check that the speakers are plugged into the GREEN port on the laptop and that the speakers are powered up with the volume at about 1/2 way.
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left) Click PROERTIES
Make sure that Volume controls, Wave, SW Synth, CD PLayer, Line IN, and MIC all show on there and that the volume sliders are about half way up.
Make sure noe of the sliders have ticks at the bottom, if so UNTICK them.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else unles you know you want that item)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
If not double check that you have no problems with your hardware from the device manager.
