95 chrysler lhs, car starts, runs for 5 seconds and shuts down. Gauges don't work, air conditioner stays on etc. I changed the computer, the fuel pump, the spark plugs, fuel filter and wires. Also the automatic door locks don't work half the time and the gas gauge sometimes goes to empty even though i have gas. how can i fix this myself?
Sounds like a bad ground or broken ground during other fixes.also try battery post to corroded or frayed wire at battery oreven low voltage in battery
As far as the running and shutting down you might try checking the EGR valve. however, this sounds like an electrical issue... a really weird one. You'll probably have to take it to a local shop that does well with electrical problems.
I suggest that you go to ALLDATA.COM and take out a subscription for ALLDATADIY, this access can give you unlimited knowledge about your vehicle. I have a repair manuel also between the two reference media I have solved most of the problems you are facing. Not to mention the problems you will be facing with a vehicle this old.
