SOURCE: Wiring harness diagram
Your question is not clear, 2002 trailblazer has a towing harness, in order to find each wire, use a ohmmeter and try out each application.
In case of male harness of a camper you can test it with 12 volts in each wire looking which light is on and if it is different position cut wires and make similar wiring
SOURCE: Remove 2001 Forester tail light (1/4 panel, not hatch light)
should just require a quarter turn of the socket to remove it
Robert
SOURCE: ive got a 2001 golf gt tdi and my glow light plug
Check your exterior light bulbs, mine use to do that all the time and then i replaced a bulb and all better, this is actually how the VW tells you your bulbs are burnt out or a circuit is not being completed , so then you take it to the shop pay 95 for a diagnostic then the idiots tell you its a 12 dollar bulb. BS. Second time mine started going was when i installed my rear tail light incorrectly and it started blinking, reinstalled and it went away. It also could be a bit more serious: Mass airflow sensor, break switch (cheap fix) If its your glow plugs or wiring harness the check engien light lights up.
SOURCE: Access to tail light wiring harness plug
You have to remove the access panel on the interior side of the passenger compartment to access that connector.. it's a simple procedure after you see the wire harness and bulkhead boot.
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
