1998 GMC Sierra Logo
Derek T Sundheim Posted on Sep 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced engine coil, drove for 50 miles and check engine light starts flashing along with the motor running very rough unless my foot was on the gas petal, replaced EGR valve and still doesn't want to run?
  • Derek T Sundheim Sep 29, 2013
    truck was running fine before i accelerated to pass another vehical and then decided to start sputtering, thth is when the check engine light started flashing?
Denis Houle
Level 3:
  • GMC Master 1,414 Answers
  • Posted on Sep 30, 2013
Denis Houle
GMC Master
Level 3:
Answers
1414
Questions
0
Helped
498634
Points
4096
Cap ,rotor ,spark plug wire , spark plug could misfire....
the check engine light flash because it's a severe misfire and fuel go to converter catalyst.
Testimonial: "all of those thing have been replaced by myself within the last year, as well i had the timing reset within the last 3 months, still not sure what to look at, this is the first time iv had this problem, but for several months it has had a hard time starting even with a brand new starter?"
5 Related Answers
Anonymous
  • Posted on Oct 11, 2008
SOURCE: 1995 gmc Jimmy
timing is off try the timming senser
66 chrgr
mike loshbough
  • 1011 Answers
  • Posted on Mar 26, 2009
SOURCE: 2001 GMC Yukon Flashing Check Engine Light
dear sir the flashing check engine light means the truck was misfiring at the time of the incident .If the light is still on you can go to auto zone they will pull the codes for you and reset the light if you like.but if running good now then probably nothing to worry about .
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Apr 21, 2009
SOURCE: The check engine light stays
its easy too replace but you need too reset your cmputer first too see if the light stays out before you go and buy the egr valve
disconnect the pos side of the battery for 5 min that will reset the computer,if the light comes back on then get the egr valve then you will have too reset it again
Anonymous
  • 3600 Answers
  • Posted on Jul 05, 2009
SOURCE: 1994 GMC JImmy 4.3 V6 running very roughly
fuel pump sock or try the egr valve to see if it is stuck open all the time. can't remember if that one has the digital one and a vachumm type as well, next would be the evaperative canister purge valve.
Anonymous
  • 336 Answers
  • Posted on Aug 17, 2009
SOURCE: my 79 Chevy has rough idle/miss at idle but runs fine otherwise
It sounds like you have a vacuum leak or a carburetor problem. Check all hoses and the line going to the brake booster for cracks or leaks. Make sure the carb bolts are tight at the manifold. You can check for leaks using some carb cleaner. Spray around the base of carb while the engine is running, any leak will cause the engine to sputter when the spray hits it. You may want to look into rebuilding the carb or replace it. If its the original its a Quadrajet, they are not the easiest to rebuild but not impossible. If you rebuild it yourself, make sure to get the numbers off the carb so you can get the correct rebuild kit and accelerator pump. Plus you should replace the float when you rebuild since its 30 years old. A thorough cleaning of the carb is crucial before rebuilding. The fuel mixture screws have caps on them so they wont be altered after assembly from the factory. You'll have to remove those caps to remove these screws before cleaning. You can probably find some good info. on doing this at a good parts store. I hope this helps you.
2007 chrysler 300 car won't start OBD light on.
Sounds like an electrical issue. You'll want to take it in.
I have a 2007 Toyota Avalon. The check engine light turned on and around forty minutes of driving it, it starts to run rough. I replaced the gas cap with a new one. I thought this would solve the...
A flashing check engine light indicates a cylinder missfire. A evaporative emissions leak (the result of a bad gas cap) wouldn't cause a rough running condition. How many miles are on the vehicle?
2helpful
3answers
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
1helpful
1994 camry 4cyl. was running great. drove it to work and shut it off, then went to start it back up and it shut right off, wont idle. I can keep it running by keeping my foot on gas and its not running...
have your idle control switch check, easy and inexpensive to replace. The idle control switch is what keep the engine stay idle. also have your throttle body clean by a professional having that many miles, it will give you better gas mileage.
1helpful
3answers
#5 cylinder misfire
I have a corolla and had #4 cylinder misfire also diagnosed at autozone. After changing the spark plugs, problem persisted, along with the same error code, so they recommended changing the spark plug wires, and that is what fixed it. I would have changed the rotor cap too, but was low on dough. Glad that was not the problem.
2answers
99 taurus running rough smells funny light flashing
The reason the check engine light is flashing instead of on steady is because it is missing bad and the car companies did this to tell you to stop the car as soon as possible to prevent damage. That is the only time the light will flash off and on instead of being on steady.
The cause is a little harder to diagnose. It could be a fouled spark plug, a bad plug wire, an injector, stopped up fuel filter. I can't remember if that car has the distributer or the coil packs but you could have a problem there. If you have never changed the spark plugs or fuel filter, it is well over a hundred thousand miles to do so now. They say to change them at one hundred thousand but 50 to 75 thousand is better and you will get better mileage. The fuel filter needs to be changed every 20 thousand miles now days because of all the cheap gas we have to put in the cars.
This is for mechanics or technicians. If no one out there believes me about the mileage on the fuel filter, then take the filter off and see what comes out the back. Looks like black water to me.
4helpful
5answers
Misfire
One question, have you replaced the ECTS (Electronic Cooling Temperature Sensor)? These cause no end of different seemingly unrelated problems on Saturns. Peice is about ten bucks and is an easy install. Just search on youtube for a how-to video. Even if that's not the problem it is reccommended to replace this peice just the same as they ALL end up going bad at some point.
If that's not a fix, start pulling plugs. Check to see if they're correctly gapped and if they have any damage/corrosion. If you're running Platinum plugs, immediatly change to a copper plug as Platinums have no place in these motors. Most people have the best luck with NGK copper.
Check to make sure that your plug wires haven't been crossed. This sounds like a plug or wire issue most likely so it has to be in that family, if the plugs are good, wires good and not crossed, sensors are fine, then time to replace your coil packs. If you've replaced everything up to the coil packs then that is most likely the cause of your dillema.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
