Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
maurice castle Posted on Sep 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp compaq evo n1015v notebook running too slow?
midland10
Level 2:
Scholar:
  • Expert 110 Answers
  • Posted on Sep 22, 2013
midland10
Expert
Level 2:
Scholar:
Answers
110
Questions
Helped
27844
Points
238
Shut pc down, restart, run antivirus scan, run hard drive defrag and clean up, shut down unecessary programs running in the background. Good luck.
1 Related Answer
A
Anonymous
  • Posted on Apr 24, 2008
SOURCE: compaq evo system running extremely slow
i agree overheating clean it out maybe remove the sink and re apply compound that may help as well
Where can i download a driver for the quick access 4 way scroll on my HP EVO N1015V laptop?
This is for windows XP... :):
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome/?sp4ts.oid=316646&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3DswEnvOID%253D1093%257CswLang%253D%257Caction%253DlistDriver&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#Firmware%20-%20Keyboard,%20Mouse%20and%20Input%20Devices
Compaq evo n1015v will not boot up when power is pressed
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-compaq-evo-n1015v-ac-adapter-90watt.html
1helpful
How do I turn on the wifi feature on my Compaq H1015v Lap top
According to the product specifications on HP/Compaqs website, this model Evo does not have wireless built in, only modem and ethernet ports are the means for getting online. A wireless usb card can be used to get wireless. Specs can be found here -
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=316644&prodTypeId=321957&prodSeriesId=316644&objectID=c00356041
If am making call with my Compaq Evo N1015v the side will not hear me but i hear them
you need to check you have a microphone, and if so go to your optons in your programm you use and set it up. most web cams come with mics built in and the programmes usually sort it automatically, if this is not the case you will need to do it manually. or you can get headphones with a microphone.
I have a password on the bios fo an compaq evo n1015v and i have forgoten it can you help please
Enter 3 time wrong password u will get a code send me that code ill send u master password thanks
I have a compaq evo n1015v laptop which comes on fine but cant really see the screen, very very dull, have changed the screen but still does the same thing???
The luminiscent tube is not powered or defective. Check the connection between the laptop and inverter board (small pc board at the bottom of the screen), between the lamp and the inverter board, the fuse of the inverter board and the lamp itself.
I use guaranteed working lamp to check if the inverter works. After that I check the lamp of the laptop powering it with another inverter, taken from a broken scanner. Inverter boards are very common and you can easily find replacement on ebay. Be careful with the voltage going to the lamp. It is very high and you can easily burn the inverter or your finger. Remove the power and the battery before opening any covers.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
