SOURCE: Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
SOURCE: i cannot find any decal that tells me the the
if its a briggs motor it is usually stamped in metal cowl either on front above sparkplug or side above muffler
SOURCE: toro recycler rear bagger linkage set-up to
Hopefully, this will clarify it..
http://small-engines.com/bsgovernors.html
SOURCE: adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
