Most likely it is a fault with the external monitor, either an inverter circuit board or the CCFL lamp. To confirm if the laptop video card is faulty, connect another external monotor to the laptop and if the monitor is OK then it confirms the Samsung monitor is faulty.
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual. Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz" - The monitor turns on but turns off by itself, the LED blinks green. - If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off. - The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable". - The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz" - The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more 220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n 220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere 220499443698
IF it is making a clicking noise it is the SUB PSU , the one that powers the embedded PC, there are 2 CAPACITORS on the PCB that will be domed at the top a 1000uf and 1500uf, they are on the secondary side , this is a common problem with this and the 460PXN (same psu) replace caps with higher voltage rating is my advice,!!! I did everything OK!!
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
