SOURCE: One channel vocals drop out
yes, it is very likely the stylus. the stock needle is conical shaped like a ball point pen. You might have a tonearm that is out of alignment but usually it's the needle. It is possible it is just dust on the tip but if it occurrs in consistent areas of the record, then it is likely that the music is just too demanding for the LP2D you will either have to use your old technics which is likely better quality or you could try upgrading the stylus on your LP2D.
If you do a yahoo search for "4-211-DE-GUARD" with the quotes, the 1st result will take you to an elliptical upgrade over the stock needle. The elliptical tip will pull more info out of the grooves and into your computer for further processing.
SOURCE: Audio Technica AT-LP2D
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
SOURCE: My audio-technica PL50 plays 45s at the wrong speed.
believe it or not not it probably doesn`t even play your lp`s at the right speed? Its probably because your drive belt has actually stretched? rubber belts do wear and maybe seek out a replacement drive belt?
try this company?
mailto:[email protected]
