Hyundai Motor 1992 Elantra Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine light comes on car will not run
Car may start and run check engine light comes on car stops will not start leave for a few hours car will start and run like new. Very intermittent every start light is on then it could go a couple of days.
  • Anonymous May 11, 2010
    take car to popular autoparts store and have them pull the trouble code for free. it won't solve the problem but it will give you a starting point to troubleshoot from. sounds like ignition coil heating up but that's a vague uninformed guess. have them pull code and get back to us
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Dec 23, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
Helped
16566
Points
187
Having the same problem. If you found a solution please post :) thnx!
1helpful
How can i fix my 2003 holden barina `eps warning light from coming on
It'll pay to have the crank sensor checked. They're known for heating up and stalling the car when they're no longer any good. Usually once it has cooled down the car will start but as soon as the sensor gets hot it'll stall again
Renault trafic wont start...engine warning light flashing
The light and the word stop should be sending you a clear message . The engine hard starting and sluggish is also sending a message and if you do not heed the message and have the fault codes read and the problem fixed then the next message may be replace the engine or gear box . The light is there --not to be an annoyance ---but to inform you that something drastic is going wrong and it needs urgent attention.
2006 Honda Element engine sputter
Temp.gauge really has nothing to do with the perfomance of the engine. If the car has been unused for a few hours, the engine oil etc settles down. It is good idea to let it run after a cold start so the oil circulates in the engine. Keep in mind it's a 1996 model and needs more care. Keep servicing regularly.
1helpful
Is there 2005 honda civic software update for po128 error code
I think we all just live in a world of automobiles,that have
too much high tech technology,when not so much is needed,
just to keep exhaust emissions at an acceptable level
At least you kept going back to the dealer & not keep driving
as most people do
You gave the dealer techs several chances at resolving the issues,
all be it, expensive, to say the least.
I don't see anything where you went wrong, or they let you down,
assuming your good to go & no more issues
I assume that the head gasket was something that only moved
& leaked internally under certain conditions & I don't know why or
when the ECU came up as a problem,they don't fail often
I have a 1997 dodge avenger es 2.5 liter here's
Check the vacuum line on the fuel pressure regulator for any sign of gas being sucked into the line. A failed regulator will let extra gas get into the engine. If it's okay, have the fuel pressure checked. That's sure a lot of gas, way too much for the engine. Good luck.
5helpful
My 96 olds does not like to start when it gets hot. seems to start ok when it cools down. Any ideas? It doesnt start real easy when its cold. have to rev a let idle a little before moving. idles pretty...
Hello, I have 1996 Ciera with rebuilt engine pretty new, also fuel filter and fuel pump replaced but I have a problem, the car starts and runs well cold but once car has been running for a few hours, either stopping or coming to a stop it starts to idle roughly and has come to a stop at different occasions. Check engine light does come on and off occasionally. Can you help?
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
