Leica Laser Alignment Lb-4 Dual Grade Slope Laser Logo
LB 4 Laser alignment laser showing E2 code. Laser beacon not rotating.
1helpful
Can someone help me with a calibration guide for a David White ael 2500 laser level
Here are the steps you can follow:
Set up the laser level on a flat surface or tripod and turn it on.
Place a target or receiver on a wall or surface where you want to project the laser beam.
Adjust the receiver to the same height as the laser level.
Align the laser level with the target or receiver.
Rotate the laser level 180 degrees and align it with the target or receiver again.
Check the readings on the receiver. The difference between the two readings should be less than or equal to the accuracy specification for the laser level.
If the readings are not within the specified accuracy, adjust the laser level until they are. Use the adjustment screws on the laser level to fine-tune the alignment.
Repeat the calibration process if necessary.
Note: Before calibrating your laser level, make sure it is clean and free from any debris or damage that may affect its accuracy. Additionally, consult the user manual for specific instructions and safety guidelines.
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
2answers
Laser Alignment 3900 lb-2. I can hear the motor running but the head doesn't spin. How do I take it apart to check the belt.
The unit is sealed with copious ammounts of RTV-11 self leveling silicone. Parts are unavailable for that unit. I wouldn't put the time and effort into it.
If your determined, dig out all the white silicone and unscrew all the screws on the bottom, until things come apart.
2answers
Parts
Unfortuinately for you (but fortuinately for thoes of us that fix them) parts have long since been discontinued for thoes units. Your best bet would be to go to an industrial or contactor hard ware store (not home depot) and see if they can come up with a similar sized O ring. Or call/email every survey/laser repair shop you can, and see if they have old stock.
2answers
CALIBRATE LASER ALIGNMENT LB4
can you inform how i can calibrate laser level alignment lb 4
I need manual for lb4
It will show Battery Protect when;
1-There are no batteries in unit.
2-The batteries are fully charged.
3-Alkaline batteries have been installed and charging is attempted.
4-The batteries are bad.
Sanyo 4400 Ni-Cads assembled in brick pack form, the Ni-Cads normally last 3-4 years and need replacement. This is an older unit that is obsolete with few parts available but there are after-market battery assemblers that can make them up just Google it.
Error code E2 0012223
Laser scanner motor error. The polygon motor does not deliver a synchronous output (L) within the predetermined period of time. The scanner unit may need cleaning. be careful as there is a laser working in this area turn all power off before attemting. The laser unit sits under the top cover.
Error code 52.0
A laser/scanner error has occurred
Recommended action:
1. From the DIAGNOSTICS menu, run the
laser/scanner motor component test.
Verify that you can hear the motor
rotate.
2. If you cannot hear the motor rotate,
verify that connector J1702 and J1505
are fully seated on the DC controller
PCA (ECU).
3. Verify that the connector J12 on the
laser/scanner assembly is securely
attached.
4. If the error persists, replace the laser/
scanner assembly
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
1helpful
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Top Leica Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
