if you have a lower version of video card I suggest to purchase a recommended one which is the 128mb, much better if you would have the 256mb for the better result.
To transfer video from this camcorder to a PC, you need a 1394 cable (also called a "Firewire" cable, and your PC must have a 1394/Firewire connector as well. You can use Movie Maker (which comes with Windows) as the capture software, or you can download Scenalyzer (shareware), Studio (from Pinnacle), or Vegas Movie Studio to do the capture.
Unfortunately is not possible directly - Your cam do not support USB streaming... But You may use any cheap video capture device like Pinnacle Studio movie box or similar to connect Your camera via S-video cable because Your camera has an analog output. Only one requirement - the capture card must have an S-video input or simply RCA video input. It's easy - connect video out and audio out of Your cam to the capture device and then connect USB of capture device to Your computer.
It is very simple. Install a Firewire (IEEE1394) card in PCI slot (if you don't have any video capture card) and connect DCR460E camcorder to PC through iLink cable. You need a video editing software like Ulead Video studio, Pinnacle studio or any other to be installed in your PC. Then go to capture mode of that programme and capture transfer video to PC hard disk. Windows movie maker is also do the same. For editing and better special effects you should use hihger versions of ulead or pinnacle. Thank you.
Gautam Kumar Mandal,
Additional Chief Industrial Engineer,
Durgapur Steel Plant,
Steel Authority of India Limited (SAIL).
if you want to transfer from VHS or an analog camcorder you need a capture card or TV card (some mother borad and graphic card have this on board).but if you have a DV camcorder check this:
if your computer and camcorder have fire wire port (IEE1394) use it and otherwise use USB (low qualty).
for software I could suggest video studio, adobe primaire (full or element) windows movie maker, or any othe program which comes with you camcorder.
I hope this helps...
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided.
After installing the driver and software, you can begin transferring data using the software provided.
Connecting to a PC
1. Connect a USB cable to the USB port on the PC.
2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack)
3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC.
Notes:
* If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged.
* If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly.
* In this case, remove the other USB devices from the PC and reconnect the camcorder.
Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Since VHSC camcorders feature only analog outputs: it is not possible to connect the camcorder directly to a PC (unless a computer video card is equipped with analog inputs). The only way to transfer images from the camcorder to a PC will be using an external device capable of analog/digital signal conversion. JVC has released a capture device model, GV-CB3U which has the capability of video capture of a single frame in either Bitmap or JPEG format. The GV-CB3 can be connected to any video source through a standard video or S-Video connector and download single image to a PC using serial port (RS232C communication port). The JLIP Video Capture software necessary to transfer images to the computer as well as connecting cables are supplied with this product. You can also use 3rd party hardware (Video Capturing device) to send information from your camera to a PC. Visit your local PC or Office store for more information on other video capturing devices.
