If you clicked repair connection at anytime, you need to reset the router, by way of a reset button on the rear or front, go to your wired network card properties in control panel>network connections, click TCP/IP line, click properties again and select obtain ip address automatically. At this point you can run the setup wizard again if you wish using the rj45 cable You should set up the router using an RJ45 lan cable which comes with the unit and get into the routers settings by typing it's ip address in your web browser 192.168.0.1. Check that DHCP is set at enabled to give your pc's an automatic ip address. Check that wireless is also enabled and save any changed settings. Go to the properties of your pc's wireless adapter in control panel network connections and on its TCP/IP line check that obtain ip address automatically is ticked. when you have set up your wireless connection and the router is set up correctly, disconnect the rj45 cable and if neccassary dissable the wired network card so as the router looks for your wireless adapter and gives it an ip address. When a connection is found by your wireless connection you need to go into the router again and set up your wireless security, using whatever method you choose eg WEP or WPA PSK. You need to select the numbers and letters mixture pass phrase that you use for encyption and use the same numbers in the wireless adapter when it asks for the passkey no., you should then be able to connect again securely.
