Heating & Cooling Logo
Anonymous Posted on Aug 28, 2013
My problem with Toyota granvia air condition is that my front air condition is not browing the air but the back one is browing and cooling .can I have the picture of the air condition system if its possible
Brian Mills
Level 3:
Master:
  • Master 613 Answers
  • Posted on Aug 30, 2013
Brian Mills
Master
Level 3:
Master:
Answers
613
Questions
0
Helped
133304
Points
1126
The compressor is fine, if the rear unit operates. Check your front blower fan for a loose/ broken wire or blown fuse.
Where is the fuse for injector on toyota regius
open glove box take out guide, see fuse page ,FI fuse is common name.
or tell facts.
20+ Petrol engines, non told, world wide( I can not guess them)
year is? 1967 to 2004? vast exits by year,engine/country)
no country told
or RTM read he service manual. ?
ask toyota for the manual , in you country
non in USA or I could read it to you.
all Regius are here, 1989 to 2004 ,
or is it REgiusACE?
Granvia, HiAce Regius, Grand HiAce, Touring HiAce (XH10, XH20)
https://en.wikipedia.org/wiki/Toyota_HiAce#Granvia,_HiAce_Regius,_Grand_HiAce,_Touring_HiAce_(XH10,_XH20)
tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
2004 Toyota Sienna XLE...overheat problem....replaced water pump, thermostat and flushed fluids and added new. Now the temp gage while driving moves up from half on the indicator to 3/4 and the air...
-Are you talking about air conditioning...?
-The fan works but not cold air at all ? that is what you asked?
-If so. then the Freon is very low or no more. Check for leak and fix before refill Freon.
Good luck
Mai
1helpful
Where the air conditionfreon go for toyota corolla dx because i get only air not cool air
ok you have a red cap and a blue cap on the air conditioning lines you need to unscrew the blue cap and charge with freon with car running if no caps the valve on top in front of car by radiator is the low side it looks similar to a tires air valve
Air conditioning not working. Blowing cool air in the back and hot air in the front.
Is there air blowing from the front vents? or can you hear the vacumm change when you change it from heat to cool..... I think it might be a vacumm problem... its a 1997 so the controller vacumm hoses may be cracking.. let us know
1987 Toyota Celica overheats when air conditioning is turned on
Hi
The first thing to check is that the engine cooling fan comes on when you turn on the air conditioning, then you should check the condition of the radiator fins. If they are clogged with debris (dead insects, leaves, etc...) then you will need to get a pressure washer onto it through the front grill and try to blast it clear.
When you switch on the aircon, it puts extra stress on the engine, which causes the fuel economy and engine power to drop, and as a result the engine will naturally run hotter, so it needs a bit of help to cool down in the form of the engine cooling fan.
Regards
Geordie
Steering rod / pinion - front L brake, 1996 Toyota Granvia 3L 4wd auto
Your e-mail was way out. Toyota Granvia is a motor vehicle. Problem has been resolved, No need to add my mystery to your list.
Top Heating & Cooling Experts
Paul Carew
john h
