The problem is most likely clogged idle jets. The solution would be to mix some additive, like B12 or Sea Foam, with your gasoline and go for a ride. You want to make sure you ride enough to get the gas into your carburetors. While riding, the additive will clean your carbs, but when you park the bike with the engine off is when it will start soaking into your idle jets. Depending on how clogged they are, it may take a while. The alternative is to remove the carbs, and clean the idle jets. I would try a couple of ounces of cleaner per gallon of gas and then ride it around and see how it works. It has worked for me 3 out of 4 times. Good luck!
Testimonial: "iftikhar, thank u so much 4 ur advice on my rc 51, it worked. mark"
Have you tried turning it on and off again?
Testimonial: "on and off again? how would that help"
SOURCE: engine idles fine, stalls soon as its given gas
Hi there!
Open up the carb and clean the jets with pressurized air. I also suspect water on the carburetor reservoir, before opening the carb, drain it first then run. Also, make sure the plugs are clean. Pull on the choke when twisting the accelerator, if it accelerates well, then warm the beast at normal temperature first before twisting the throttle hard again.
hope this helps-
levibit-
SOURCE: scn@bike will start, but with
That is a safety deature. It would not be a good idea to ride off with the side stand down!
There is a micro switch connected to the side stand and clutch lever for your protection.
Engine stalls or RPM
fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
thank you iftikhar,b12 worked for my rc51, you have a bike?
