SOURCE: A604 solenoid pack interchangability
If I remember right the 2000 solenoid pack is slightly different than the '96. I've only seen that happen myself once. I just called my local bone yard and got a solenoid pack from the same year of trans. and did it that way.
SOURCE: dodge caravan 1998 start problem (alarm set)
I have had the same trouble with my 1998 Dodge Caravan, so has my neighbor on both of his caravan vans and We have found that if we slap down on the dash above the temperature gauge it will work just fine.
we both lose speedometer and fuel guages too! Same fix
about once a month I will have to slap it, to get my guages back, and stop the alarm.
I believe it is a bad soldiering connection in the dash but it is not worth chasing it down when I can get by without it.
when the post said the van worked fine after being towed it is because the connection was made while the van was jostled around being loaded and transported
SOURCE: Car alarm goeoss car will not start
<Have heard that putting key into ignition in 'on' position and waiting
sixty seconds for alarm to go off, then turning key off and back on
will disable alarm. Haven't tried it yet.>
rweh is correct! Thank you! It worked for me!
SOURCE: heat climate control doesn/t blow warm air when on lower setting
It sounds like the blower resistor is shot. Just change out the resistor and that should take care of it.
SOURCE: program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION:
The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable.
SERVICE INFORMATION:
The keyless adapter cable can be used on the following vehicles:
NOTE
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
and press ENTER
NOTE
"Release date 29. Sep. 2003" OR LATER
must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
and press ENTER
and press ENTER
on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
and disconnect the adapter cable from the multi-purpose connector.
