1999 Ford Expedition Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Location of low side ac port
Can you please provide me with a diagram/location of the low-side ac port on my vehicle to check for ac problems?
  • 1 more comment
  • inlouisiana7 Apr 08, 2009
    Thank you
  • Anonymous Mar 17, 2014
    My expedition has the low ac port on the drivers side
  • Anonymous Mar 24, 2014
    location
Marvin
Level 3:
Top Expert:
  • Ford Master 85,242 Answers
  • Posted on Apr 07, 2009
Marvin
Ford Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060708
Points
266281
The low side charging port is near the AC Accumulator/Reciever dryer cannister in the larger of the 2 AC lines.
  • Anonymous Aug 07, 2013
    Ware do I get the adapter to fit the store bought 134a slip on fitting
tip
Air conditioning
When an vehicle's air conditioning system has not been used for several months, the seals within the system start getting dry. I've never worked on a Peugeot 206 or any other peugeot before, that's why I had no idea where the low pressure ac port was. The high pressure ac port is the easiest to locate, because it is in the engine compartment, facing the car from the front, on left side of the radiator. The low pressure ac port is in the engine compartment, facing the car from the front, to the back in the center, under the windshield. The low pressure ac port and the high pressure ac port both have black dust caps. The low pressure ac port is the smaller of the two.
on Jun 14, 2015 • 2003 Peugeot 206
Location of low side ac port on 1992 dodge ram 5.9 deisel
The best solution
you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc.
Location of low side a/c port 2003 lincoln ls v6
Todd, Low side A/C port, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2000 Lincoln LS AC Low pressure port Location
2005 Lincoln ls low pressure port
low side port 2003 lincoln ls v6 Google Search
Where is the low pressure ac port located?
THE LINES THAT RUN FROM THE AC ARE TWO SIZES. THE SMALLER DIAMETER IS THE HI SIDE. IT RUNS FROM THE COMPRESSOR TO THE CONDENSER. THE LARGER DIAMETER IS THE LOW SIDE AND RUNS TO THE EVAPORATOR INSIDE THE CAR. THE FILLER FOR THE LOW SIDE IS ON THE LARGER LINE. IT WOULD HELP TO KNOW THE CAR IN QUESTION WHICH WASN'T PROVIDED
4helpful
I need to locate the low side ac port. air conditioner needs charge and i cannot locate the right port.
The easiest way to locate the low side charge port on any vehicle is to locate the A/C compressor, follow the "larger" of the two lines all the way back to the firewall. Some where along that line you will find the low side charge port.
Good luck.
Regards,
Audi A4 Ac charge valve.
On that year a4 and a6 there is no low side charging port. (sucks)
The way you charge those systems is by evacuating all of the refrigerant, then with the vehicle off, add the correct amount of refrigerant to the high side port (turning the compressor over by hand occasionally)
3helpful
2answers
I NEED A DIAGRAM OF WHERE TO RECHARGE THE AIR CONDITIONER
The Low-side port is just about dead-center in front of the engine. Right in front of the exhaust manifold, and between the two radiator fans. It may have a blue or black plastic cap on it.
The High-side port is on the driver-side (US) behind the coolant reservoir, below the cruise-control motor. It usually has a red cap.
Of course the Low-side is where you would attach the freon supply.
Caution: messing with AC systems can be dangerous to your property, vehicle, and your person. If you have any doubt about what you are doing or what to connect, where, don't! Always use eye protection and gloves to protect your hands.
1helpful
AC Low Pressure location on 2004 Chevy Suburban
You find the AC low pressure at the top of the compressor, orientated toward you , facing the front of the vehicle. You can also follow the compressor line to reach the port.
The valve is covered a plastic cap covering it.
Near the compressor you find two ports, the high port and low port.
To find out which one is the low port, run the air conditioner for a couple of minutes withthe engine on.
Then turn off the care and touch the lines from compressor to the two ports covered with plastic caps. Only one of the pipes will be cold, the cold line will lead you to the low port.
Regards.
2000 vw cabrio where s the ac low side service
Possibly located under the cowl near the windshield under plastic piece on passenger side of vehicle.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
