I can put it from neutral into first, but then its a problem getting it back into neutral, whats the problem??
If the bike hasn't been used for a while the clutch plates may fuse together and need to be removed,seperated,cleaned and put back together.OR the plates may be warped.replacement for this one.Easiest to do is that the clutch may just need adjusting.Hope this helps
Your clutch is maybe malfunctionning.
Check if your clutch cable is tight enough.
