Samsung AW1203B Air Conditioner Logo
A
Anonymous Posted on Jul 30, 2013
Samsung AJ50 - Samsung AW1203B Air Conditioner
3helpful
Need a manual for a Aiwa model# CX-NAJ5OU
http://www.manualslib.com/manual/3631/Aiwa-Nsx-Aj50.html?page=3
1helpful
2answers
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
1helpful
Am not playing, but fm plays fine. am doesn't seem to pick up any signal. Any suggestions.
Hi
AM portion of the receiver may have gone bad. AM is usually the easiest to tune in unless your in a dead spot.
11helpful
4answers
2helpful
2answers
My Compact Disc Stereo System NSX-AJ50 is tripping off every time I turn it on. Henry [email protected] Thanks.
One or more of the output transistors has failed or you have a bad speaker. Try disconnecting both speakers and turning on the unit. If it still shuts down, then the transistors are likely to be defective. These can be replaced for about $15-$25 plus labor at any service shop that handles audio gear.
Dan
5helpful
2answers
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Aiwa nsx-aj50
The power supply, and or the output stage can fail in these units. This may be on the expensive side to service.
Jerry G.
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
