Samsung AW1203B Air Conditioner
Problems with Samsung AW1203B Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Samsung AW1203B Air Conditioner RSS Feed
Click here to get instant support from our best Experts!
View More Results for Samsung AW1203B Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Samsung AW1203B Air Conditioner RSS Feed
Answer
en el display de mi aire acondicionado muestra e4 y sale fuera de servicio unidad de aire... (More)
Answer
samsung awt18wbhdf no cooling ice formation
Answer
El Equipo funciona normal pero luego de unas 2 o 3 horas aparece " E4 " lo apago y lo... (More)
Answer
my air is getting power but when i push the power button it does not respond
Answer
i need to buy the control remote for an AW1203B samsung air conditioner
Answer
I dont know how to resolve it... I tried the Up and down arrow keys.. there was a beep for every... (More)
Answer
sensor wire was pulled out. air conditioner will not work now. can this be fixed?
Find a Manual
Samsung AW1203B Air Conditioner Manuals & Guides
Tips & Tricks
(Post a New Tip)
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
Air Conditioner Trouble -Review the Possibilities
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check... written by heatman101
Air Conditioning - Cleaning the Condenser Coil
Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles... written by heatman101
testesttest
test test tes test written by bstreet
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for AW1203B Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Ratings for the Samsung AW1203B Air Conditioner
Owners Recommend
out of 2
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for Samsung AW1203B Air Conditioner
Other Features
Moisture Removal (Pt/h)
1.5
Filter
Reusable
Air Flow
370 CFM
Swing Louvers
Up / Down · Left / Right
Cooling Operating Range
70 - 90
Key Features
Type
Thru-Wall/Window
Remote Control
With Remote Control
Dehumidifier
With Dehumidifier Functionality
Cooling Capacity
12400 BTU/hr
Energy Efficiency Rating
9.8 EER
Fan Speeds (Cooling)
Electrical Requirements
Voltage
115
Cooling Ampacity
11.3
Cooling Watts
460
Dimensions
Depth
19.5 in.
Height
15.19 in.
Width
22 in.
Warranty
Warranty
1 Year
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Air... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
