getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
? 15:01
https://www.youtube.com/watch?v=GYrFFrbWm5U
Dec 3, 2010 - Uploaded by georgef551
This is a review of the Discovery Wonderwall MultimediaProjector, ... twist the lens to focus the image, up to at least 120" (can go farther), but you'll ... RGB elements, which stands outlike a sore thumb when video gets .... The bulb will just make the display more true, and possibly, ... sound compared to 3m?Missing: power power
Amazon.com, Inc.
Rating: 2.7 - 60 reviews
Amazon.com: Discovery Expedition Wonderwall Entertainment Projector: ... color contrast, volume control, distinct power on/off button, LED indicator light .... A lot of reviews complained about the fan noise and speaker level, but I thought .... I got it for Christmas to play video games on and you can't even make out the words.
The wonderwall does NOT have the proper inputs for use with a computer for good reason.
A wonderwall projector is NOT a projector that is good enough to be used for movies or games and it would be embarrassing to make a presentation on one. It has WAY less resolution than even old fashioned standard definition TV. Standard def Tv is 720x 480 pixels at 30 cycles. A wonderwall is 480x 240 pixels which is appx. the resolution of a screen on your phone. That's 345,600 for STANDARD def versus only 115,200 pixels for a wonderwall. When you blow that up to 3 feet wide, it'll look pretty mediocre. We have one just like it and we use it to project VHS onto our garage during Halloween and Christmas.
It IS perfect for fun and might be ok to watch old VHS tapes but watching a dvd on one is horrible.
Your 1440 has VGA outputs. A wonderwall has AV (red, white yellow) inputs. You can buy a vga to AV adapter for less than 10 dollars almost anywhere. You don't even need to go to a specialty electronics store.
Connecting an External Monitor or Data Projector You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Did you figure this out? I have the same problem. We probabaly used it 10 times aand no video. I thought the light bulb may be bad. I picture a new one and still no picture. I know the video is hooked up properly. If you leave the back door (where you change the light bulb) off and shine a flashlight in there, the video projects on the screen. Something is wrong with getting electric to the light bulb.
how do you fix this problem
