SOURCE: Water dispenser problem?
grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
SOURCE: water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
SOURCE: AEG Santos S83168KD1 - The
Hi there. Here are few tips on how to reset AEG refrigerators
Control Panel (water dispenser) I J N M O K L I. Yellow indicator lamp Lights up when the locking function has been activated. J. Button for carbonated water. - Used for the choice of carbonated water. - For the engagement and disengagement of the locking function. K. Button for ordinary water. - Used for the choice of ordinary water. - Switches the background lighting on and off. - Switches off the indicator lamp for water filter replacement. L. Yellow indicator lamp Lights up when the water filter must be changed. M. Water out-feed Activated when a glass or something similar is pressed upwards against the flap. N. Flap O. Lighting AEG/Electrolux 8183969-01/6 9 The functions of the water dispenser The locking function: The locking function is activated by the production plant. For temporary unlocking: Keep the button (J) pressed in for about three seconds until the yellow indicator lamp (I) goes out. The locking function is re-activated automatically after about three seconds. For permanent unlocking: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. The button (J) or (K) lights up to indicate unlocking. To activate the locking function: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. Activation is indicated by the yellow indicator lamp (I) lighting up.
Click the link i have provided to you for the service manula of your refrigerator. Scroll down and look at the right side then copy all document on the text box then paste it to microsoft word. Please click here for the manual.
SOURCE: Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Hello friend, I appreciate your inquiry!
I understand that your Frigidaire refrigerator is not dispensing any water and you have checker the filter and pressure. I would check to make sure that there is not a lock on your dispenser. Also, make sure that the house supply is turned on fully. I would check to make sure that your water line does not have a restriction in it. If everything appears to be working properly you might need to have a technician come and accurately diagnosis your refrigerator. Hope this information is helpful. -Matt
