so what makes you think the laptop has BT? its and option on all PC made, when new (check this first)
is this the only BT device you own? do tell. and can be added to any PC on earth with a BT USB dongle stick. for like $4 what is the distance to the speakers (BT uses radio signals weak) 10ft 50 ft (10 meters) what? distance matters on all transmitters regardless if BT, wifi, wlan, or 3g/4g/. etc...
BT comes in 2 power settings, some devices do not use high power mode. (on speakers this would make for best) does the speakers pair with any other PC? with BT?
the speakers if not junk has RTM manual. and read the page on how to reset pairing. BT loves to memorize your favorite devices, so if problems happen. learn how to reset that memory , call reset pairing history.
To Pair: 1. Turn on your Bluetooth speaker (slide switch to BT) 2. Light on bottom should turn on Blue. If not, plug speaker into USB connector and bottom will turn Red to indicate it's charging. 3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT. 4. Enter pairing code (passcode): 0000 or you can try: 1234
To Pair: 1. Turn on your Bluetooth speaker/headphones (slide switch to BT) 2.
Light should turn on Blue. If not, plug speaker into USB
connector and light will turn Red to indicate it's charging. 3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT. 4. Enter pairing code (passcode): 0000 or you can try: 1234
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
