Nikon D70s Digital Camera Logo
Posted on Mar 30, 2009
I have a Nikon D70 and am unable to insert memory card all the way, i double checked that it is the correct card and inserted the right direction.
Anonymous
Level 1:
  • Contributor 18 Answers
  • Posted on Mar 30, 2009
Anonymous
Contributor
Level 1:
Answers
18
Questions
Helped
4282
Points
69
STOP! You have just bent a few pins. Your camera has a male connection. Meaning it has pins sticking out. If you are unable to insert a memory card, that means a pin is bent and is not going into the holes in your memory card. This is a common problem with cameras that accept a compact flash card. This can be an easy fix or it can be a very hard fix.
Ive fixed a couple of cameras like this with a pair of tweezers. flash light (or some big source of light) and a magnifying glass. You need to look into the slot on the camera under light and look at all the pins sticking out. Look for the bent pins and use the tweezers to bend them back. Be careful not to keep bending the pin back and forth, as this will break the pin off. Ive seen cameras work without certain pins, but this is not something you want to do.
To have an SLR fixed is a minimum $160 dollars depending on where you take it too. The D70 is a good camera.
Please do not stick the memory card back in. Check the memory card to make sure all the holes are clear and have nothing blocking the holes or make sure a hole has gotten bigger and merged into one. I would use a different card once the pins are are sticking straight.
Hope this helps you.
I have a Nikon d70 SLR. I had this camera completely cleaned and tuned up 3 months ago. Recently I can not take pictures. The battery powers the camera, but the shutter wont engage. An "error" message...
Read the manual on how to do a two-button reset. Also: from the nNikon Support Page on the D70::
It has come to our attention that select electrical components in a limited number of D70 cameras may, in some instances, fail affecting camera performance and/or operability.
While only a limited number of D70 cameras are affected by this advisory, if (1) when a memory card is inserted, your D70's memory card access lamp blinks, locking camera operations and preventing operation, or (2) with no memory card inserted, the camera will not turn on despite the battery indicator showing a fully charged battery, Nikon Inc. will service it free of charge.
To obtain complimentary service for cameras affected by this advisory, please click the link below to download and print the Service Return Form. The Service Return Form provides return instructions.
The Frequently Asked Questions button at the bottom of this page offers more information about this advisory and, should you have more questions, also provides information about how to contact Nikon.
We apologize for any inconvenience you may experience.
tip
Nikon offers Free Repairs on the D70, D2H, F55
Nikon has posted the following notice on its Support page for the D70 / D2H / F55 cameras:
" It has come to our attention that electronic components related to exposure control in some D70 cameras may, on rare occasions, fail.
Should you experience this problem with your D70 camera, Nikon will replace the associated components free of charge even if the camera’s warranty has already expired. We sincerely apologize for any inconvenience you may have suffered because of this problem."
To check if your camera has failed due this reason, please read the symptom description as follows:
How can I identify if my camera is faulty?
With a memory card inserted: The green memory card access lamp blinks continuously and camera does not respond to any controls.
With no memory card inserted: The camera will not turn on despite the battery indicator showing a fully charged battery.
How can I contact Nikon on-line?
You must be registered for Nikon support. Make sure that all your personal details are registered in full and are up to date, as these will be used if you return your product to us. You must also register your D70 and serial number.
1. Register for Nikon Support.
If you are not registered for Nikon Support, create a new account. If you already have an account, check that your personal details are up to date and that you have registered your product and serial number. To do this, login and click the ‘My Account’ tab, then click the ‘Profile’ sub-button. When finished, click the ‘Save’ button at the bottom of the page.
2. Submit your Question
Click the ‘Ask a Question’ tab near the top of the page and fill in the required fields, please add the words ‘D70 notice’ to the ‘Title’ field and add your comments to the ‘Question’ field.
When you have finished, click the ‘Submit Question Button’ and then you will be asked to click the ‘Finish Submitting Question’ button on the last page.
We will endeavour to answer your question as soon as possible.
NIKON Support:
http://nikoneurope-en.custhelp.com/cgi-bin/nikoneurope_en.cfg/php/enduser/std_alp.php?p_sid=yHTDQxQh
on Apr 06, 2010 • Cameras
1helpful
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Have a Nikon D70, tried to load the memory card into the slot, and the grey button doesn't pop out when the card is put in the slot....the card wont go the whole way in
If there is nothing obstructing the slot, and you are inserting the card correctly, check the sides of the memory card to see if they are not damaged.
5helpful
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Digital Nikon D70S - memory card removed while turned on.
Hi - You can download the manual by clicking the link underlined in blue below:
Nikon > D70
See page 200:
Try resetting the camera in this way first to see if it clears the problem.
The -E- means that the camera cannot detect that a memory card is present see page 199.
Check that the card is properly inserted (page 20) and as a last resort try formatting it (you will lose any pictures on it):
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
2answers
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 • Cameras
1helpful
2answers
Nikon D70 won't recognize the 2 GB, type II memory card
Try to clean the contacts of the memory cards and, mostly, of the memory card bay of the camera. Use a dry anti-static fabric (e.g. what we use to clean eye-glasses). DON'T use any liquid cleaner of anything like that!
Crash
The D70 has a reset button at the bottom of the camera. Firts of all, I think you have checked you have the correct lens inserted (at least D mount) and well done, checked your memory card is correctly inserted, and if you have another, change it.Checked the battery. Looked the AF modes on the body. If everything is OK, then press the reset button. If you have no answer, then take the camera to the T. Service.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
