Question about Weather King 10AJA6001AH Air Conditioner
Model 10ajb30a01 how may BTU's does this unit have?
I have a Weather king Model Number 10AJB30A01, serial # 6933T360407047. What tonnage is this. I would like to fit it to an existing airhandler that I have.
In some unit you can find it from the model number. Only 10 or 30 is what I can see from your model. Read the brochure of your unit to confirm the correct ton of your a/c unit.
Sep 03, 2011 | Heating & Cooling
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
I have an oddball question. What does a 3-ton A/C unit weigh? I know its not 3 tons.
Not every 3-ton unit weighs exactly the same - they differ in weight depending on how they were manufactured. Most 3-ton units weigh around 150 pounds (I would guess) give or take a few pounds.
The "3-ton" refers to the "cooling capacity" of the air conditioner.
It's actually 'slang' for 36,000 Btu.
Note; 12,000 btu equals 1 ton.
Hence a 24,000 Btu unit would be called a "2-ton unit," and a 12,000 Btu unit would be called a 1 ton unit.
Aug 05, 2011 | Heating & Cooling
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
How many btu's does kenmore model # 580.72056 have
About 5400 BTU's, approx large enough to cool a 12x12 area without overtaxing the AC unit.
Jul 03, 2011 | Kitchen Ranges
I have a Fedders A6X08F2A-B Service # and Serial # MP 178550 and I would like to have the specs on it eg: how many BTU's, model # etc
Hi, The numbers you have given tell me, this unit is a 8,000 btu unit.!2, 000 btu's equal a ton of cooling, so you are just under a ton. This is about all I can tell you. There should be a data plate that will give you amps, volts, compressor amps ect.
Shastalaker7
A/C, Contractor
Jun 10, 2011 | Fedders X Chassis A6X08F2A Air Conditioner
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
Whirlpool window a/c model: acm152xlo How do I find out how many BTU's this unit has
That model number indicates a nominal capacity of 15,00 BTU, so it should be within 500 BTU on either side of that
Hope that helps
May 11, 2011 | Heating & Cooling
Weather King 10AJA6001AH Air Conditioner Logo
133 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
