Gigabyte GA-7VA Motherboard Logo
Michael Cleverley Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motherboard Simple PCI Communications Driver Code 28 for modem
Need a driver for a PCI Simple Communications Controller for the above motherboard
  • Anonymous Mar 31, 2014
    Missing a driver
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
785238
Points
9440
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Pci simple communications controller driver xp
This is a modem or network card. You must... Never mind.
Here it is.http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=820&MenuID=21&LanID=0
Pci simple communications controller Motherboard G31M-S
Access the manufacturer's web-site: http://www.asrock.com
Enter the model-number of your motherboard, and do the search for downloadable device-drivers.
Look for the "network adapter" or the "modem" device-driver for your "unknown" communication-device.
PCI Simple Communications controller
Hi, yes you need the right driver, do a google search for the driver, there are many sights where it will be free.
1helpful
2answers
Did a clean install of windows xp SP2 and am unable to connect to the LAN connection between the NIC board and the broadband modem. Error message tells me simple communications controller is missing. What...
Hello.
When you performed the Windows XP install, not all the drivers were available and installed.
Hope this helps.
2answers
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
your computer need to install the drivers for modem. because the simple communication controller name is used for the modem
Ethernet won`t start
you will need to rinstall its drivers, insert your motherboard CD and reinstall the network adapter. then reboot
2helpful
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
1helpful
2answers
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
4helpful
3answers
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
