having a non-authorized repair center open your watch voids all manufacturing warranties. Invicta cannot guarantee the quality standards of an altered timepiece, the standard 3-year limited warranty on Invicta timepieces shall be invalid if the timepiece is serviced at any time by an unauthorized repair center. This includes battery replacements, which must be done at an Invicta authorized repair center in order to maintain the eligibility of the warranty.
Thank you for writing down what UPS it is and thanks for all the info you put on here. It help out a lot. If this is happing you might have a bad battery. Remember it only takes one bad one to fail. So if you can find the manual, note down how many times it beeps. In the back of the manual you will see, Troubleshooting Guide, there should be a section where you can decipher the beeps and it should tell you what alarm it is. Example 2 Beeps every 3 second intervals could indicate Low batteries, meaning your battery capacity is not at 100%. Need to replace the unit or the batteries. Again this an example. Also don't disconnect it unless you are ready to loose you power to whatever you are backing up. (Computers or printer, etc.) Not unless it doesn't matter what it's backing up.
B1 means Bank one where the number 1 cylinder is S1 means the up stream sensor the one before the catalytic converter,or the first sensor. Hope this helps if not get back to me and we'll go from there. Please rate my fix as i strive to be the best, Thanks Ray
Yes, that means that the battery is low and needs replaced. You can go to a Liftmaster Dealer and get part # Liftmaster 485LM. There should be two wires that attach to the battery. Just make sure the unit is unplugged when you replace the battery.
Do you mean camera does not show live image to take pictures and it shows previously taken picture properly in playback? If thats true, then it is most likely bad ccd imager that needs to be replaced. Canon will replace it free of cost, click Canon CCD Imager Advisory for details. Thanks.
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
