Bass wooper keeps going off and radio will change channel on its own
SOURCE: protection mode override
If you have your subs wired to the amp in a bridged configuration, try wiring one to each stereo channel instead. Also, make sure your ground wire is secure and connected to a clean, solid metal part of the vehicle body with the paint scraped off. If this doesn't work, disconnect both subs and try connecting only one at a time; one of the subs may have a problem that is shutting down the amplifier.
SOURCE: Sony Xplod 2-Channel 1000 Watt Amplifier trouble shooting
What's the model number of the amp?
What speakers do you have on the amp?
Are the speakers moving significantly at high volume?
SOURCE: Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
SOURCE: how to record a cassette from cd
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
