There are 2 popout screws that can be removed after opening the rear door. This did not seem to unseal the light, though I think I was doing it correctly. It still is on there pretty solid, & I do not want to force it off & break it.
1.
Disconnect and isolate the battery negative cable.
2.
Open the liftgate to access and remove the two push-pins (3) that secure the rear lamp unit (1) to the side jamb (2) of the liftgate opening.
3.
Pull the outboard side of the rear lamp unit rearward far enough to unsnap the two ball studs on the outboard side of the lamp housing from the two plastic grommets (6) in the quarter outer panel.
4.
Pull the lamp away from the vehicle far enough to access and disengage the retainer on the body wire harness (4) from the tab on the lower lamp housing.
5.
Disconnect the body wire harness connector from the pigtail wire connector (5) on the back of the lamp housing.
6.
Remove the lamp from the lamp opening of the quarter outer panel.
Hope this helps.
Replacing tail/brake/backup lights and turn signal bulbs (coupe)
1. Make sure the headlamp control
is in the OFF position and then
open the hatchback.
2. From inside the luggage
compartment remove the wing nut
of the rear light assembly cover.
3. Using a Phillips screw driver
remove the screw. The lamp is still
retained by a spring loaded clip.
Remove by gently pulling out the
light housing.
4. Turn the bulb socket counterclockwise as far as possible and pull it
out.
5. Pull the bulb straight out of the socket.
Install in reverse order.
Replacing tail/brake/backup lights and turn signal bulbs (sedan)
open the trunk.
compartment remove the three wing
nuts of the light housing.
3. Gently pull the light housing to
the outside.
counterclockwise and pull it out.
Replacing tail/brake/backup lights and turn signal bulbs (wagon)
open the hatchback.
2. Using a screw driver remove the
fixings and trim from the body.
3. Remove the socket from the lamp
assembly
4. Pull the bulb straight out of the
socket.
Hope this helps.
Zeppelinx12
