I have an Emerson Air Conditioner wall unit. I would like to remove the front cover and clean the panel with metal fins. How do I do that?
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
SOURCE: Emerson Air Conditioner #10HW42K through wall
First off, my model # is Emerson Quiet Kool 10HW42K. No it is not yet solved, however I am reaching out to a number of sources. Was hoping to get a simple answer since it is not a "repair" problem, but rather a "replacement problem". I am looking for another AC that will fit the original sleeve.
SOURCE: Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
SOURCE: How to take apart case and back flush heat exchange fins
You do not have to remove the coils. Just carefully lift the top with the motor and set it aside (power off). Spray the outside with a foaming cleaner (Dow bathroom) and flush from inside out.
