Hi
I have the same notebook and I have changed the hard drive on mine as well.It is quite simple really,you will find on the side of the A drive it sits just above it,to remove it there is one screw on the underside if you follow it in line and guess the depth of the A drive you will see it all by itself.
Just unscrew it and slide out the drive.The hard drive is a slim line compartment that sits on top of the A drive.
Just pull it out as it just slots in/out.
Just slot ou new hard drive in screw up the single screw and presto you should have a new hard drive ready to go.
Hope this helps,I have ram probs not sure where to slot the 256MB RAM into,maybe you could help me.
Regards
Iain
Dear Iain,
Thank you for your advice.
There is only one ram slot underneath the keyboard. Press the release on the right side of the keyboard near the screen, slide the whole panel off towards the left. The keyboard can be lifted up, be careful of the flat connector and do not bend it but keep it attached. The Ram housing is concealed under a black plastic cover.
Hope this helps. It can only take a maximum of 256MB Ram PC133 if the slot is still empty.
Best regards,
Romaleouf
