SOURCE: 2001 dodge ram will not idle stalls in lower rpm
its not the fuel filter sounds more like a bad ais motor
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
SOURCE: 2001 Dodge Ram 1500; how to reset computer after replacing dead battery
disconnect the positive battery cable for 2 minutes and that will reset the computer
SOURCE: rough idle and misfire on ram truck
Change cam sensor & erase codes.( disconnect battery for a minute or so after.) 340 & 1391 refer to cam sensor problem, and all other 300 codes are cylinder misfires that should disappear when cam sensor fixed.
SOURCE: Remove headlight assembly from a 2001 Dodge Ram
On the upper grill side of the headlight assy. there
should be 1 or 2 push pins that hold the seal on the
headlight assy to the front of the fender. Also check
for a guide/push pin on the inner top of the assy on
the outer fender side. That should be all there is to
hold the headlight in place. Hope this helps.
