Hi
i have fujitsu siemens lifebook t3010 . i all ready installed winxp sp2 but in my laptop some sofware are not working .i.e
writing pad,bluetooth.
so please solve this problem
thanks
But did you formated all by you? did you already installed drivers for those that don t work? usualy those drivers are not inside xp SO so you would need to install it using support download
I removed harddrive from tablet pc and copied neccesary files onto drive via USB to IDE adapter. Then re-installed harddrive into tablet pc and now it works.
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Use a USB driver or download the windows OS on your hard drive and install from there. both should work as long as you setup will boot to USB devices.
Good Luck.
one more option connect to a network that has Windows OS installable on the server or other computer then install to your tablet.
to connect yo,r pen in usb port and anotner one solution is to uninstal your usb drivers in yo,r devicemanager and restart your system then connect your pen
