Did you mount the coil and set the air gap correctly there is a cylinder side marked on the coil if all that is correct check it by unplugging the ground wire and try
Those cars are notorious for engine problems unfortunately. The exhaust valves tend to warp from heat after around 200k miles. Therefore throwing the O2 codes. Best outcome and cost effective thing I can recommend is replacing the engine with a new or low mileage engine.
their are two spark control features one is the pick up coil it's mounted under the distributor the other is in the distributor it the control module check the pink wire that plugs into the distributor for power
This is a fairly easy job. Do each cylinder one by one (removal and install), make sure to reinstall the coil on the same exact cylinder (DO NOT MIX UP). 1. Remove coil retaining scre 2. Pull upward on the coil to remove. 3. Remove spark plug (using a spark plug socket). 4. Properly gap new spark plug (if applicable). 5. Apply sprark plug anti-seize compound on plug threads. 6. Install plug. 7. Aplly coil boot grease on the coils' rubber boot tips. 8. Reinstall coil.
check and see if you have spark at the coil you can do this by getting an inline spark tester no more then ten dollars if you have spark then try replacing the distributor
do you have spark out of the coil into the cap? if so i would suggest removing the cap and testing for continuity between the center plug (coil input) and the spring loaded button on the inside also check the rotor, if you have no spark from coil at all be sure you have it wired correctly and be sure the coil wire did not get pulled apart in the ends please rate -jeff
