SOURCE: Gas pouring out of carb into air box
sounds like it take bottom of carb off and see if needle is stuck
SOURCE: Had trouble get bike to run after sitting for 2
the float may need to have an adjustment or be checked for parts in the right way.(fuel not being regulated by the float, is caused by worn or damaged needle,or still got trash) once you get this solved the grinding will not be so bed(you will have more safe control of rpms)
SOURCE: I have a 1991 honda cr 250 I cant get to start at
try a new spark plug. if u fowl out a plug some time they will not fire under compression.2 strokes need. fuel,fire and air, very simple engines.it is possible crank seal are bad .that doesn't allow the engine to create vacuum in the crank case.thus fuel and air will not make it to combustion chamber.
