SOURCE: I have a Fujitsu Lifebook
the plug size of your headphones is too small and no sound will come out. buy ones for a computer and use those.
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Please check the voltage at the pin end of the laptop using a multimeter in the voltage range. If absent then there is fault in the adapter and must be opened to confirm or replace.If present then connect and check the voltage at the pin end of the battery terminal in the laptop , if present the battery is a suspect.Check this link: http://www.fixya.com/support/r5164850-laptop_power_supply
SOURCE: Fujitsu LifeBook AH531 screen
It could be the inverter that runs the back light.
Have a look around maybe on Ebay, it's cheaper than a another new screen. Take yours out of the laptop and look for any names or numbers on it to make sure you get the correct one.
Testimonial: "Thanks, Stuart... I didn't know; I will look into it. HL"
SOURCE: Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
Switching the wireless components on/off - that's Fn+F5 - according to the Operating Manual for Lifebook AH531
