Question about Fujitsu LifeBook AH531
Cannot get boot menu on fujitsu lifebook ah531
When i first startup and see the fujitsu logo i cannot get into boot menu or bios. i press f12 but nothing happens at all. please help me
Posted by merriusaquar on
  • Anonymous Apr 04, 2013
    I am having the same problem but I don't know what to do about it. I have tried all the things suggested by people such as unscrewing certain things and checking the battery etc but nothings working for me. When I press F2 it says please wait or when I press Esc it gives me the same two options which are F2 and F12. When I click the F12 button it does not work but when I click the F2 button it says Entering SETUP, but it has been like this for a long time now. If you have yours solved help me please because I have some very important things on my laptop.
  • Karim Allam Jun 10, 2013
    press f12 many times and quickly
Herwin Pradana
  • 177 Answers
Try del or F8
but i recommed you to go to the BIOS setup,and set the boot priority
it's saver,and easier
Posted on Aug 22, 2012
  • macnica2007
    macnica2007 Dec 30, 2012
    How do you setup the BIOS because it gives you the Boot priority order:1. Floppy Disk Drive 2. Dive0 HDD: WDC WD3200BPVT-16JJ5TO 3. CD/DVD Drive: TSST corp CDDVDW SN-208AB 4. Network: Realtek PXE B07 D00 5. USB HDD: 6. USB CD/DVD:
dawndancer19
    New Friend:
The problem is you can't enter BIOS, i have exactly the same problem or enter the boot menu has anyone got a fix?
Posted on Apr 12, 2013
5 Related Answers
Sunnyrepairs
Suuny Kohn
  • 808 Answers
SOURCE: How do I update the BIOS for my Fujitsu Lifebook
U can chek this link for bios update http://www.pc-ap.fujitsu.com/support/manual_lb.html Or http://driverscollection.com/?H=C2210&By=Fujitsu
Posted on Jul 28, 2010
StuartB
Stuart
  • 807 Answers
SOURCE: Fujitsu LifeBook AH531 screen
It could be the inverter that runs the back light.
Have a look around maybe on Ebay, it's cheaper than a another new screen. Take yours out of the laptop and look for any names or numbers on it to make sure you get the correct one.
Posted on Feb 05, 2012
Testimonial: "Thanks, Stuart... I didn't know; I will look into it. HL"
Kiran Anto
  • 420 Answers
SOURCE: By mistake I changed my BIOS password., but I
Just go to here
Enter your model and hash code and they email back your bios master password for your Laptop/computer.
Posted on Sep 17, 2010
Suresh Ayyar
  • 1481 Answers
SOURCE: FUJITSU LIFEBOOK N3530, INTEL CENTRINO DUO. THIS
check the BIOS...
check the boot sequence in bios...
may be it's not set to boot from HD....
pls let me know if u can make changes in BIOS and can set HDD booting...
i will explain how to do it if u need...
have u formated and reinstalled windows...?
let me know more details pls...
Posted on Dec 21, 2009
Anonymous
SOURCE: Lifebook Fujitsu A6020 does not boot up. Hear hard
Hey, i have exactly the same problem with exactly the same computer.
Did you repair yours?
Posted on Feb 24, 2010
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspireâ„¢ T180 PC Desktop
How to change boot order on Lenovo M57 to usb
Enter BIos ( F1)
Go to startup sequence
locate the excluded device
Press X and set the device in the desire boot order #
Press F10 to save.
Aug 06, 2012 | IBM Lenovo ThinkCentre M57
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
My hp zt 1170 battery will not recharge in the notebook, I have removed and replaced it. I saw that I needed to update my bios and tried the bootable floppy drive I downloaded to update by BIOS but when I...
Try tapping the F12 key during boot. That should bring up a menu of bootable devices. Select the floppy drive.
You can also change the boot order in the BIOS.
Make *absolutely sure* you are plugged in when you flash the BIOS!
Mar 21, 2011 | HP Pavilion zt1170 Notebook
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12...
Welcome to FixYa! The problem that you have is about the Operating system and there are two ways of fixing the problem which is by using the Recovery Disc or using the One Key Recovery Button. Please follow the steps below for you to be able to fix the problem. If everything is done and its still the same, most probably, the problem is with the Harddrive.
For One Key Recovery:
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
Oct 11, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Ibm t21 turn on to start up page with diaganol ibm logo and press f1 for bios f12 for temporary boot device,but it just hangs there the f1 & f12 buttons dont do anything any help much appreciated
The cpu looking for a file or driver so go to F1 and click on F10 and exit and see what will happen? If that did not work restart the computer and keep clicking on F8 tell you get a new menu asking you to select one of the followings, one of them safe mode, or last know good configurations, etc. Select last know good startup.
If you need help with anyone then please let me know and I will help with it. Please do not forget to rate my service so we can improve on it with your help. God bless
Sep 30, 2009 | IBM ThinkPad T21 Notebook
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
My toshiba p105 with windows xp won't boot and i want to reformat it. I have the bootable disc but when I use the c key to boot from it, nothing happens and the usual message I have been getting, We are...
What you want to do in this matter is, go into the BIOS if you haven't done that already, and change the boot device priority to CD. You want to do the following right when you startup the computer, and without the CD in the drive. BIOS/Setup Utility, can usually be found be pressing the delete key at startup, or the F12 key at startup, so push one of those two keys a few times to get to the BIOS utility. The setting to change the boot order of devices is usually one of the menu options at the top of the screen, closer to the right side. Once you find how to change the boot order, change the first device that the computer boots to to the CD you've got, insert your CD, save the BIOS settings and exit, and you should be set to go.
Apr 13, 2008 | Computers & Internet
Fujitsu LifeBook AH531 Logo
Top Fujitsu Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Davit Mamyan
Davit Mamyan
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
