Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
I already replaced the door seal last month, thanks and it was fixed. I pulled the machine out opened the bottom inspection panels. Found crack in the discharge tube. The hose broke down where it should have been fine. Replaced the hose and re-installed. Its a good machine fortunately the floor was ceramic tile and I did not face floor damage. Still like the dishwasher, when it works. Thanks George
I have the seal out of place. Can anyone describe the process to replace or repair the door seal for the LG dishwasher.
