Akai LCT2662 Television Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No 12volts and 5 =volts in secondary transformer
Radames Pagan
Level 3:
President:
  • Master 196 Answers
  • Posted on Apr 23, 2010
Radames Pagan
Master
Level 3:
President:
Answers
196
Questions
Helped
70000
Points
1123
Change all 470mf & 1000mf caps fix problem
Anonymous
Level 1:
Problem Solver:
  • Contributor 26 Answers
  • Posted on Apr 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
26
Questions
Helped
14195
Points
28
A transformer rated 480/110/220 volt, single phase. The currents on the secondary are 16 amps on L1, 27 amps on L2. What is the primary current on the transformer?
Assuming L1 terminals are the 110 V output and L2 are the 220V output, then the theoretical 440V input current for a 100% efficient , i.e. lossless, transformer would be 17.5 amperes.if the secondaries are delivering the specified currents. More realistically the input current might be 2 to 5% higher since transformer generally run at 95 to 98% efficiency. 18.5 amperes would be an approx result.
Amps at 440 V = ((16 x 110) +(27 x 220)) /440
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 • Pool & Spa
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
What is the secondary voltage of power transformer
The schematics do not show the actual voltage.
From the design, the phantom power secpndary should be around 35 to 45 volts AC.
The 16 volt supplies would require a secondary winding that will be around 26 to 32 volts center tapped.
Transformers are quite reliable and unless a voltage is missing, the transformer is likely OK.
The most suspect items are the electrolytic filter caps if the voltage is not the design 16 plus and minus values.
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
2answers
No power to thermostat
You need a serviceman. No really, you do! You are in over your head and you are replacing parts just because you can see them and they are not the likely culprit. I am betting it is the contacters in your condensing unit.
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
2helpful
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Tips how 2 wind transformer ac -dc .output 12volts. in put 240
your windings of primary to secondary must be in a ratio of 20:1. That is, for a primary with say, 100 windings and input 240 VAC, 5 secondary windings will give you 12 VAC. you need to rectify then regulate if you want 12VDC. Just buy an off the shelf wall-wart.
1helpful
2answers
HID headlight
Most likely the HID transformer is not producing the correct voltage to properly charge the HID bulb. 12 volts goes into the transformer, but a lot more comes out. The HID needs a lot of volts to run, hence the need for the abovementioned transformer. But, the transformers are REALLY expensive.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
