Computers & Internet Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Dimension 8200 turns off in BIOS
On the back there is a yellow light on A and D and green lights on B and C. I checked the connections on the ide cable to the hard drive and they're not loose. I am trying to reinstall windows XP using the cd rom. The cd rom works and is connected with the ribbon-orange. The hard drive was tested- I connected it to my other computer as slave drive - and it was recognized. I connected it to the blue ribbon. Is the motherboard dead? Is the cpu dead? During the BIOS the message is-'' several attempts have been made to boot--call dell support''. Error message for check Hdsk.
Is the drive bad even though it was recognized on another computer?
Is the IDE controller bad? I'm confused.
  • 2 more comments
  • Anonymous Mar 16, 2009
    It is a Dell Dimension 8200. It goes through POST and shuts of by itself when trying to load windows xp. I will try and replace the ribbon cable and see what happens.Thanks to everyone.
  • Anonymous May 11, 2010
    Have you had your computer open? If so, then make sure that all the cards on the left hand side of it are pushed in tightly. There could be a loose card or something could be wrong with your motherboard. Let me know if this helped.
  • natepooh May 11, 2010
    It is also possible it is just a bad ribbon cable.
    what's the harddrive manufacturer?
    also is machine turning off when doing POST or it goes through POST and then reboots when trying to load windows?
Anonymous
Level 2:
Scholar:
  • Expert 81 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
81
Questions
0
Helped
20207
Points
208
If the dianostic lights A & D are yellow an IDE bus failure has occurred. Reseat the IDE cables at the motherboard and drive(s). If this does not resolve the issue you may need to contact Dell for a motherboard repair or replacement.
I have 2 amber / yellow and 2 green lights on can you help please
Well, I\'ll go with Dick\'s solution. Its the Problem in your Ram or motherboard\'s ram slot. Check One by one both the ram and the slots.
1helpful
3answers
When I turn on the dell dimension 8200 the light on the power button does not turn green, it stays amber color blinking and the computer does not turn on, is it the power supply that is gone bad?
Check all below possibilties & see if it works.....
  1. GGGY diagnostic lights can indicate a bad motherboard, or possibly a hard drive failure.You could try opening the case, then remove and reseat all the power and data cables, cards and memory and see if the system bootsCheck for burnt/charred power connectors on the motherboard and for any capacitors with bulging tops or are leaking, the tops should be perfectly flat.
  2. Could you please check out if the you are not having a battery problem. This could be the source of all the trouble that you are having.
  3. do the fans and hard drives spin
Please rate & vote, if you like solution
Thanks
Sandeep
1helpful
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
3helpful
Need cmos jumper location on Dell Dimension 8200 to bypass bios password
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
3answers
Dell 8200 Dimension shuts down on bootup. Making
The clinking sound could well be your drive heads snapping back into parking location if your power supply is going out. Since the 8200 comes with a pretty weak power supply those tend to go out shortly after you've upgraded to a better graphics card or added another drive to the system. I've replaced mine a few times and now have a 450 watt supply in it which seems to be able to handle a powered video card and the 2nd HD, 2nd dvd without running out of juice.
Another good thing for these old dimensions is the addition of a case /slot fan to help with cooling a bit more. (see included picture)
I've had dealings with a number of dimensions from this era not cooling enough and the slot fans really helped stability.5a04930.gif
Let me know if any of this helps your situation.
1helpful
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Dell Dimemsion 8200 Won't Boot - Beeping Sequence 5-2-2-1
Often simply disconnecting the power cable, holding power button for 15 seconds, release power button, plug back in will work
Otherwise remove CMOS battery and perform above operation
Hope it works
2helpful
Need picture of dell dimension 8200 back panel
Here is a link to Dimension 8200 Front view and Back view: http://support.dell.com/support/edocs/systems/dim8200/tour.htm#1101572
The speaker jack is Green.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Grand Canyon Tech
Grand Canyon Tech
