There two wires one short and broken the other is connect can you help me
Just buy a wire connector for that size wire and reconnect the broken wire. Wire sizes vary by uses with the lower numbers being thicker wires. I would guess the wires you have are around a 14 gauge or a 12. You will need a connector that has that diameter to allow a proper fit. There are connectors which crimp together. The more modern screw together.
SOURCE: horn not working on a 2006 ford f250 xlt
The cause of this is not the horn or fuse in most cases, it is caused by the rotating contact that connects the horn button, in order to repair this you will need a new clock-spring contact, to install the airbag must be disarmed, his has to be done by the book or serious injury can result.
SOURCE: need the radio wiring diagram for expedition 98
http://www.installdr.com/Harnesses/Ford-Wiring.pdf hope this link helps. Good luck. Keep me posted.
SOURCE: 1996 Ford Explorer XLT abs light comes on on
The ABS light is for the Anti-lock Braking System. The MIL will illuminate if there is a difference in wheel speed sensors signals to the PCM. So you might have a wheel speed sensor that is going out on you. Does the light come on at low speeds, or just higway speeds? You could take the vehicle to a local parts store and have them pull the codes for you and that will tell you which speed sensor is out of whack. Also road grime, dirt and gunk buildup can cause speed sensors to give false readings. Hope tihs helps you out.......
