No manual provided with faucet. What size are these fittings?
The fittings on the hot/cold supply hoses will be 3/8". If you have straight ends on the hoses you will need 3/8" nut and ferrules to connect to your 3/8" service stops. They will connect the same as old style soft copper tubing. If there are nuts on the hoses they will fit direct to your 3/8" service stops. If you need further help feel free to contact Hansgrohe Technical at 1-800-334-0455.
SOURCE: kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
SOURCE: water is plugged by minerals etc in my Hansgrohe kitchen faucet
You will need a flat head or a knife. You sould be able to pry it apart if not they are so cheap, pick one up at walmart, lowes etc. Bring the old one with you. Some of the tread patterns are diffrent
SOURCE: trouble connecting supply lines--leaking/Hansgrohe kitchen faucet
You are probably missing the feral (sp?) that belongs behind the nut on the compression fitting. The feral looks like a coper or plastic ring for your finger that is also slightly coned shaped....http://images.google.com/imgres?imgurl=http://www.plumbingmall.net/catalog/ferrules_thumb.jpg&imgrefurl=http://www.plumbingmall.net/servlet/Categories%3Fcategory%3DPIPING%2BSYSTEMS:PLUMBING:MANABLOC%2BACCESSORIES&usg=__EswgpaP-RUncJqHYNZbLDFsAw0E=&h=77&w=83&sz=2&hl=en&start=3&um=1&tbnid=qzemJ2Zin0P1MM:&tbnh=70&tbnw=75&prev=/images%3Fq%3Dplumbing%2Bferrule%26ndsp%3D18%26hl%3Den%26client%3Dfirefox-a%26rls%3Dcom.ubuntu:en-US:official%26hs%3Dhh9%26sa%3DN%26um%3D1
SOURCE: I have a Hansgrohe kitchen faucet model P-IX
Is this the Axor model with one handle? Of so you need to get a new element - the central piece inside the faucet - from Hansgrohe which costs about $45. It comes with a little repair kit that has very low quality instructions.
You need to use a metric tool #3 to unscrew the little piece in the back of the handle - then the handle comes off. You have to pull it hard to get it off.
The repair kit that comes with the element has a tool to screw off the main collar of the faucet and pull out the old element. The tool is a piece of junk that bends out of shape immediately and doesn't open the collar, and possibly cuts your hand in the process. Somebody at Hansgrohe was too busy having a coffee break to figure out that by the time you repair one of these units, it's probably been in service for several years and has a good deal of corrosion and means you need to good solid tool to unscrew the collar. The tool they send is pathetic. It's actually better, if you can, to use the side of it across the two niches in the back of the collar to make the turn. You may need to give the collar a few whacks with a small hammer to loosen it, but be careful not to hit the visible part of the faucet, is it will dent easily and not look so great after you complete the repair. Once you get the collar out the replacement isn't very hard. I've done this repair twice and am so irritated by the lousy instructions and bad tool that I'll never buy another piece from Hansgrohe.
SOURCE: How do I remove cartridge
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:[email protected]
