MP-F60 model, usb cable lost, so card connected to PC via USB multicard reader, std format from windows xp used, FAT option. Any special mpman format needed? SD card works fine in PC.
You will not be able to transfer the songs to your media card and then transfer it to your device..
you will need to transfer it directly to your device from the computer...if you want i can send you a link where you can obtain your device USB cable.
Let me know if you need additional help
Thank you
Computerrep
Start up a computer with
Windows XP, Vista, or Windows 7. Insert the SD card into an external memory
card reader or into the computer's built in card reader. If it the first time a
SD card has been inserted into the computer, Windows will recognize the SD card
and automatically install drivers to read the memory card.
Go to the computer
view by clicking on the windows start menu icon in the bottom right corner of
the computer. In Windows 7 and Vista click "Computer". In Windows XP
click "My Computer"
Right click on the
SD drive under the computer heading. A dialog box with different options for
the drive will appear. Click on "Format" to bring up the formatting
dialog box.
Select the type of
formatting (also known as file system format). In Windows XP or Vista there are
several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added
choice called exFAT formatting. This is an improved FAT formatting type with improved
meta data capabilities. Choose the formatting type, name if the drive if
desired, check or uncheck the "quick format" option, and press the
"Start" button. When the SD card format is
complete Windows will provide a notification.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
pls send me the way to get the lost USB cable.
anyway, fresh formatted SD card inserted in mpman is not seen, display says 00MB, shouldn't say the 128MB it has?
pls send where to get USB cable
