The little lights which are the ones that come on when indicating to light up that side are always on and thats both of them not just one how can i turn these off is there some reason for it? dont want my battery going flat all the time
A light that says OD in a car means that Overdrive is On or Off. If the light is flashing it could mean there is something wrong with your transmission. You should take your vehicle to the nearest mechanic to get it looked at.-------------------------------------------------------------------------------------
BMW CAS3 PROGRAMMER Tool
Probably the delay switch is not working, if you have any, or the switch is bad
SOURCE: Warning light on dash says "Lights" but all lights work?
Disconnect vehicle battery for 2 minutes, reconnect battery and vehicle will do a system check, if all is ok the light will go out.
SOURCE: after locking my car, the indicator lights and side lights flash
there's a problem on your alarm sensor, try to go to your nearest dealer for that matter.
yes it's most likely a alternator problem,usually the internal diode bridge breaks causing all lights you mentioned to come on,if this happens at a idle open the hood and remove green connector on alt.if lights go out you've found the problem
SOURCE: battery warning light coming on after a mile , but
Check your alternator as it sounds like it may be starting to go. The battery light trips when it detects an issue with the charging system. Very rarely, the battery light can trip if there's an issue with the PCM, but this is very rare.
Take a voltmeter with the car off and measure the voltage on the leads of the batter, should be
around 12V+-.2. With the car running, measure again and this time it should
read 13V-14V. If it does read 13V-14V then it means that the alternator
is working. If it is below 12V, then it means your alternator is not
charging the battery properly. If it's above 14V, then it means your alternator
is overcharging and damaging the battery.
SOURCE: Day time running light problem
The problem with the DRL issue describd in the above posts is the DRl module(it needs to be replaced). The buzzing relay and intermittent on/off of passenger side DRl are indicators that the module needs to be replaced.
