Red Rim of Death when I switch on my XBOX360! It's no longer covered by warranty! Please help
Log into the xbox.com site and register your xbox for a replacement, after entering your serial number on your xbox you can check if the xbox is really out of warrenty, because of the regular accurance of Red Rings of Death Microsoft has extended warrenty on xbox's that fail because of this
if your xbox is even out of the RROD extended warrenty
the only things you can do is buy a new one or do the towel trick
please check your extended warrenty before attempting the towel trick as it will void your warrenty
the towel trick overheats your motherboard so the thermal paste melts back onto the motherboard, please note this is a completely temporary trick to get your xbox working again
to do the towel trick, unplug everything from your xbox (hdd, Video cables) just have the power cable plugged in, wrap your xbox in 3 or 4 towels and turn it on, either by pushing through the towels or by using your controller, leave the xbox on for 5-10 mins
unwrap your xbox and turn it off
leave the xbox off with everything unplugged for 2-3 hours if not longer (the longer the better, you want to make sure your xbox has completely cooled down) then after it cooling down completely (remember, 2-3 hours minimum) turn your xbox on and it should work, it may experience a fault or two, but a couple of resets generally fixes this, remember this is temporary, might get another month or so out of your xbox
how do i get microsofts number as i fone there xbox support line and was put on 2 a automated ansewr michen
thanks il try it
