Cars & Trucks Logo
Nadia Posted on Mar 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electronic pressure control solenoid circuit p1745. Check engine light on 2000 ford escort, 4cl, automatic. Advance auto told me it was a dealer part but I can't find it on any of the ford websites? How urgent is this to get fixed, and how expensive might it be? My transmission shifts hard into second, but my car is also idling wicked hard to the point of almost stalling out. Is this related to the needed part?
ZappaNut
Level 3:
  • Cars & Trucks Master 960 Answers
  • Posted on Mar 23, 2013
ZappaNut
Level 3:
Answers
960
Questions
Helped
308685
Points
2820
Here is what the service manual says about the EPC solenoid, the processor looks at allot of different inputs to command the solenoids, such as Throttle Position Sensor, Vehicle Speed Sensors, Transmission Range Sensor and RPM signal, The PCM controls the shift patterns for the transmission. Electronic Pressure Control (EPC) Solenoid
The electronic pressure control (EPC) solenoid is located on the main control valve body and is controlled by the PCM. The EPC controls line pressure used to apply and release clutches and bands in the transmission.
The 2-3 shift solenoid is located on the main control valve body and is switched on and off by electrical signals from the PCM. The 2-3 shift solenoid activates the 2-3 shift valve which controls the automatic shifting between second and third gear. Second gear is established when the 2-3 shift solenoid is switched on. The 2-3 shift solenoid is switched off when vehicle speed increases and requires a second to third gear upshift.
The 3-4 shift solenoid is located on the main control valve body and is switched on and off by electrical signals from the PCM. The 3-4 shift solenoid activates the 3-4 shift valve which controls the automatic shifting between third and fourth gear. Third gear is established when the 3-4 solenoid is switched off. The 3-4 shift solenoid is switched on when vehicle speed increases and requires a third to fourth gear upshift.
4 Related Answers
Anonymous
  • 1124 Answers
  • Posted on Jul 08, 2009
SOURCE: 2000 ISUZU TROOPER WITH AUTO TRANSMISSION. CHECK
If the fluid is up -
it could be a vacume loss or the shifting module..
The shifting module is what tells it to shift - and it is controled by vacume pressure..
Anonymous
  • 1861 Answers
  • Posted on Jun 09, 2009
SOURCE: 06 Corolla Pressure Control Solenoid D Electrical Fault
There is a technical service bulletin to correct this condition. Replacement of the car's Electronic Control Unit (the computer) will cure this. Take it to a Toyota dealer and have them replace it for free.
Anonymous
  • 333 Answers
  • Posted on Sep 21, 2009
SOURCE: Pressure Control Solenoid D electrical fault (P2716)
There is a Bulletin on this concern, and it is a warrantable condition for 8 years or 80,000 miles so you are still covered by the factory warranty.
The problem is a logic issue in the PCM. The correction is a new PCM with updated software.
Reference bulletin #TC015-07
The contents are below:
TRANSMISSION & CLUTCH
TC015-07 Title:
HARSH SHIFT AND M.I.L. "ON"
DTC P2716 Models:
'05 - '07 Corolla & Matrix (1ZZ-FE) September 20, 2007
Introduction
Some 2005 - 2007 model year Corolla and Matrix vehicles equipped with an automatic transaxle may exhibit a harsh shift condition and a M.l.L. ON" with DTC P2716 stored.
Improvements have been made to the Engine Control Module (ECM) (SAE term:
Powertrain Control Module/PCM) to reduce the possibility of this condition occurring.
Applicable Vehicles
^ 2005 - 2007 model year Corolla and Matrix (2WD) vehicles equipped with the 1ZZ-FE engine.
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle's in-service date.
** Please be sure to rate me if this free information has been helpful!
Testimonial: "Thank you so much!! "
Robert Debison
  • 412 Answers
  • Posted on Dec 30, 2009
SOURCE: trouble with the transmission solenoid
USUALLY A SHIFT SOLENOID DTC IS REPAIRED BY REPLACING THE TRANS SOLENOID PACK ASSEMBLY..LOCATED ON OUTSIDE OF TRANSMISSION..YOU MUST BE CAREFUL WHEN CHANGING PACK..CLEAN ALL DIRT/DEBRIS FROM OUTSIDE OF PACK..YOU DON'T WANT ANY DIRT TO ENTER TRANSMISSION..SOLENOID IS A SMALL BOX LOCATED ON SIDE OF TRANS FACING FRONT OF VEHICLE..YOU MUST REMOVE TRANS COOLER LINE HOSES FROM FITTINGS ON TRANS..REMOVE INPUT SPEED SENSOR..UNPLUG PACK..8MM SCREW HOLDS IT..3 BOLTS HOLD PACK TO TRANS..YOU MUST CLEAN ALL GASKET RESIDUE THOROUGHLY BEFORE INSTALLING PACK..I'D RECOMMEND GETTING SOMEONE WHO HAS DONE THIS BEFORE IF YOU ARE NOT COMFORTABLE DOING THIS..I HOPE THIS HELPS
tip
Ford OBD-II Trouble Codes
P1000 OBD-II Monitor Testing Incomplete<br />P1001 KOER Test Cannot Be Completed<br />P1039 Vehicle Speed Signal Missing or Improper<br />P1051 Brake Switch Signal Missing or Improper<br />P1100 Mass Air Flow Sensor Intermittent<br />P1101 Mass Air Flow Sensor out of Self-Test Range<br />P1112 Intake Air Temperature Sensor Intermittent<br />P1116 Engine Coolant Temperature Sensor is out of Self-Test Range<br />P1117 Engine Coolant Temperature Sensor Intermittent<br />P1120 Throttle Position Sensor out of range<br />P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor<br />P1124 Throttle Position Sensor out of Self-Test Range<br />P1125 Throttle Position Sensor Intermittent<br />P1127 Heated Oxygen Sensor Heater not on During KOER Test<br />P1128 Heated Oxygen Sensor Signals reversed<br />P1129 Heated Oxygen Sensor Signals reversed<br />P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1<br />P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1135 Ignition Switch Signal Missing or Improper<br />P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1<br />P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1<br />P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2<br />P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2<br />P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2<br />P1220 Series Throttle Control fault<br />P1224 Throttle Position Sensor B out of Self-Test Range<br />P1230 Open Power to Fuel Pump circuit<br />P1231 High Speed Fuel Pump Relay activated<br />P1232 Low Speed Fuel Pump Primary circuit failure<br />P1233 Fuel Pump Driver Module off-line<br />P1234 Fuel Pump Driver Module off-line<br />P1235 Fuel Pump Control out of range<br />P1236 Fuel Pump Control out of range<br />P1237 Fuel Pump Secondary circuit fault<br />P1238 Fuel Pump Secondary circuit fault<br />P1250 Lack of Power to FPRC Solenoid<br />P1260 Theft Detected - Engine Disabled<br />P1270 Engine RPM or Vehicle Speed Limiter Reached<br />P1288 Cylinder Head Temperature Sensor out of Self-Test Range<br />P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range<br />P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range<br />P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition<br />P1309 Misfire Detection Monitor not enabled<br />P1351 Ignition Diagnostic Monitor circuit Input fault<br />P1352 Ignition Coil A - Primary circuit fault<br />P1353 Ignition Coil B - Primary circuit fault<br />P1354 Ignition Coil C - Primary circuit fault<br />P1355 Ignition Coil D - Primary circuit fault<br />P1356 Loss of Ignition Diagnostic Module Input to PCM<br />P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range<br />P1359 Spark Output circuit fault<br />P1364 Ignition Coil Primary circuit fault<br />P1380 VCT Solenoid Valve circuit Short or Open<br />P1381 Cam Timing Advance is excessive<br />P1383 Cam Timing Advance is excessive<br />P1390 Octane Adjust out of Self-Test Range<br />P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage<br />P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage<br />P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed<br />P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose<br />P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose<br />P1407 EGR No Flow Detected<br />P1408 EGR Flow out of Self-Test Range<br />P1409? EGR Vacuum Regulator circuit malfunction<br />P1409? Electronic Vacuum Regulator Control circuit fault<br />P1410 EGR Barometric Pressure Sensor VREF Voltage<br />P1411 Secondary Air is not being diverted<br />P1413 Secondary Air Injection System Monitor circuit Low Voltage<br />P1414 Secondary Air Injection System Monitor circuit High Voltage<br />P1442 Secondary Air Injection System Monitor circuit High Voltage<br />P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault<br />P1444 Purge Flow Sensor circuit Input Low<br />P1445 Purge Flow Sensor circuit Input High<br />P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction<br />P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank<br />P1455 Substantial Leak or Blockage in Evaporative Emission Control System<br />P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction<br />P1461 Air Conditioning Pressure Sensor circuit Low Input<br />P1462 Air Conditioning Pressure Sensor circuit high Input<br />P1463 Air Conditioning Pressure Sensor Insufficient Pressure change<br />P1464 ACCS to PCM High During Self-Test<br />P1469 Low Air Conditioning Cycling Period<br />P1473 Fan Secondary High with Fans Off<br />P1474 Low Fan Control Primary circuit<br />P1479 High Fan Control Primary circuit<br />P1480 Fan Secondary Low with Low Fans On<br />P1481 Fan Secondary Low with High Fans On<br />P1483 Power to Cooling Fan Exceeded Normal Draw<br />P1484 Variable Load Control Module Pin 1 Open<br />P1500 Vehicle Speed Sensor Intermittent<br />P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure<br />P1502 Invalid or Missing Vehicle Speed Message or Brake Data<br />P1504 Intake Air Control circuit malfunction<br />P1505 Idle Air Control System at Adaptive Clip<br />P1506 Idle Air Control Over Speed Error<br />P1507 Idle Air Control Under Speed Error<br />P1512 Intake Manifold Runner Control Stuck Closed<br />P1513 Intake Manifold Runner Control Stuck Closed<br />P1516 Intake Manifold Runner Control Input Error<br />P1517 Intake Manifold Runner Control Input Error<br />P1518 Intake Manifold Runner Control fault - Stuck Open<br />P1519? Intake Manifold Runner Control Stuck Open<br />P1520? Intake Manifold Runner Control circuit fault<br />P1519? Intake Manifold Runner Control fault - Stuck Closed<br />P1520? Intake Manifold Runner Control fault<br />P1530 Open or Short to A/C Compressor Clutch circuit<br />P1537 Intake Manifold Runner Control Stuck Open<br />P1538 Intake Manifold Runner Control Stuck Open<br />P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw<br />P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection<br />P1550 Power Steering Pressure Sensor out of Self-Test Range<br />P1605 PCM Keep Alive Memory Test Error<br />P1625 Voltage to Vehicle Load Control Module Fan circuit not detected<br />P1626 Voltage to Vehicle Load Control Module circuit not detected<br />P1650 Power Steering Pressure Switch out of Self-Test Range<br />P1651 Power Steering Pressure Switch Input fault<br />P1700 Transmission system problems<br />P1701 Reverse Engagement Error<br />P1702 Transmission system problems<br />P1703 Brake On/Off Switch out of Self-Test Range<br />P1704 Transmission system problems<br />P1705 Manual Lever Position Sensor out of Self-Test Range<br />P1709 Park or Neutral Position Switch out of Self-Test Range<br />P1710 Transmission system problems<br />P1711 Transmission Fluid Temperature Sensor out of Self-Test Range<br />P1713<br />thru<br />P172 Transmission system problems<br />P1729 4x4 Low Switch Error<br />P1740 Transmission system problems<br />P1741 Torque Converter Clutch Control Error<br />P1742 Torque Converter Clutch Solenoid Faulty<br />P1743 Torque Converter Clutch Solenoid Faulty<br />P1744 Torque Converter Clutch System Stuck in Off Position<br />P1745 Transmission system problems<br />P1746 Electronic Pressure Control Solenoid - Open circuit<br />P1747 Electronic Pressure Control Solenoid - Short circuit<br />P1749 Electronic Pressure Control Solenoid Failed Low<br />P1751 Shift Solenoid No. 1 Performance<br />P1754 Coast Clutch Solenoid circuit malfunction<br />P1756 Shift Solenoid No. 2 Performance<br />P1760 Transmission system problems<br />P1761 Shift Solenoid No. 3 Performance<br />P1762 Transmission system problems<br />P1767 Transmission system problems<br />P1780 Transmission Control Switch circuit is out of Self-Test Range<br />P1781 4x4 Low Switch is out of Self-Test Range<br />P1783 Transmission Over-Temperature Condition<br />P1784 Transmission system problems<br />P1785 Transmission system problems<br />P1786 Transmission system problems<br />P1787 Transmission system problems<br />P1788 Transmission system problems<br />P1789 Transmission system problems<br />P1900 Transmission system problems
on May 23, 2011 • Ford F Cars & Trucks
2answers
Yes I have a 2000 Saturn sl2 and they told me at advance auto with hooking this thing up to there computer that a code came up for transmission showing the solenoid A is bad this car has 5 solenoids d
comment on the code number that was showing as each code refers to a specific solenoid. Also what the symptoms were that required to have the codes read.
P1745
I will try to post a URL for you. This is suppose to take test tools. Go to JustAnswer.Com/Ford/3qw6y-Diagnose-P1745-Transmission-Code.HTML. I used a Google search to reach this site as a search result for Ford Code 1745. This article has diagrams and photos and there is little I can add that is not shown.
My engine light is on, had it diagnosed. Can you explain F.P.C. solenoid circuit in a mazda, where is it located and cost involved to repair?
Step 1:
P1745 - Transmission system problems.
The code for this concern is related to the EPC solenoid in the transaxle.
P1745 EPC EPC solenoid circuit failure EPC solenoid, circuit or PCM shorted or open. Soft/harsh shift feel
The wire to the EPC solenoid is a yellow and violet wire.The code indicates that the problem is strictly caused by this solenoid circuit. I would suggest inspecting this wire from the trans to the PCM.If there are no obvious faults, replace the wire with a new wire ,eliminating the faulty circuit. Hope this helped you.
Step 2:
It's located inside the transmission. You must remove the pan and filter to get access to it.
Step 3:
As for the price you really need to get it diagnosed further.
1helpful
My service engine light is on, I had the code checked and it said line pressure solenoid. how do I find out which one is bad and where are they located
p1745 - Transmission system problems.
4helpful
3answers
Check engine light comes on after approx. one minute. My code reader gives me a 214 in continuous memory ( cylinder ID circuit failure). I clear the code and it comes back. What is giving me this code?...
look 214 is not a valid code for a 1995 escort, this is an OBD1 system. here is a list of trouble codes for this year of ford no matter the model.
You should find the diagnostic connector under your hood normally by the fender on the battery side. By just using your test light and a jumper wire, it will tell you what kind of problem you got.
KEY ON ENGINE OFF (KOEO) TEST
Model years 1984-1995 all models of Ford
1. Make sure engine is fully warmed. If in doubt, run engine at 2000 rpm for 2 minutes.
2. Turn ignition off and wait 10 seconds for system to shut off. Make sure A/C is off and transmission is in Park (automatic) or Neutral (manual).
3. Hook up light and jumper (or a tester if you have one). Turn key to ON (do not start engine). Read the codes.
How to do it?
Example code 23: your test light should flash 2 long consecutive flashes followed by 3 short pulses.
Ford's common codes for OBD1 (vehicles made before 1995)
11 system pass
12 idle control fault
13 dc motor did not move
14 engine rpm signal fault or PIP circuit failure
15 eec processor or power to KAM interrupted
16 rpm to low to check oxygen sensor test or fuel control error
17 cfi fuel control system fault or rich/lean condition indicated
18 ignition diagnostic monitor (IDM) circuit failure
19 cylinder identification (CID) sensor input failure
21 engine coolant temperature (ECT) out of self-test range
22 manifold absolute pressure (MAP) sensor circuit out of range
23 throttle positioner sensor out of self-test range
24 air charge temperature (ACT) sensor out of self-test range
25 knock not sensed during dynamic response test
26 transmission fluid temperature out of self-test range
28 loss of primary tach, right side
29 insufficient input from vehicle speed sensor
31 egr positioner sensor below minimum voltage
32 egr positioner sensor below closed limit
33 throttle positioner sensor noisy/harsh on line
34 egr valve circuit out of self-test range
35 egr valve circuit above maximum voltage
38 idle track switch circuit open
39 axod torque converter or bypass clutch not applying properly
41 oxygen sensor circuit indicates system always lean
42 oxygen sensor circuit indicates system always rich
43 oxygen sensor out of self-test range
44 air injection control system failure
45 coil 1 primary circuit failure
46 coil primary circuit failure
47 4X4 switch is closed or oxygen sensor failure
48 coil primary circuit failure
49 electronic transmission shift error
51 engine coolant temperature sensor circuit open
52 power steering pressure switch circuit open
53 throttle position circuit above maximum voltage
54 air charge temperature circuit open
55 key power input to processor open circuit
56 mass air flow circuit above maximum voltage
57 axod circuit failure
58 idle tracking switch circuit fault
59 automatic transmission shift error
61 engine coolant temperature circuit grounded
62 converter clutch error
63 throttle positioner circuit below minimum voltage
64 air charge temperature circuit grounded
65 charging system over voltage
66 mass air flow sensor circuit below minimum voltage
67 neutral/drive switch circuit open
68 transmission fluid temperature over temperature range
69 transmission shift error
70 data circuit communication link circuit failure
71 message center circuit circuit failure
72 insufficient manifold absolute pressure (MAP) change during dynamic response test
73 insufficient throttle positioner (TPS) change during dynamic response test
74 brake on/off (BOO) circuit open
75 brake on/off (BOO) circuit closed
76 insufficient air flow output change during test
77 brief wide open throttle not sensed during test
78 power interrupt detected
79 a/c on/defrost on during self test
81 map has not changed normally
82 super charger bypass circuit failure
83 OIC-low speed fuel pump relay circuit failure
84 egr vacuum regulator (EVR) circuit failure
85 canister purge circuit failure
86 shift solenoid circuit failure
87 fuel pump circuit failure
88 electro drive fan circuit failure
89 transmission solenoid circuit failure
91 no oxygen sensor switching detected
92 shift solenoid circuit failure
93 throttle positioner sensor input low
94 torque converter clutch solenoid circuit failure
95 fuel pump secondary circuit failure
96 fuel pump secondary circuit failure
97 transmission indicator circuit failure
98 electronic pressure control circuit failure
99 eec has not learned to control idle
8helpful
3answers
I have a 1999 ford escort zx2 2.ol i got a p1745 code what do i do
The wire to the EPC solenoid is a Yellow and violet wire.The code indicates that the problem is strictly caused by this solenoid circuit. I would suggest inspecting this wire from the trans to the PCM.If there are no obvious faults, replace the wire with a new wire ,eliminating the faulty circuit. Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11helpful
2helpful
2001 ESPACE 2.0L AUTO NO REVERSE HELP PLEASE
your trans has lectronic controls to operate the shifting of your trans. If there is a defect, a fault code will be stored in the computer, called a DTC. You need to have someone with a scan tool check for the fault code. It is likely a solenoid that is not working or stuck.
Get the codes first. Autozone can run the test for free on engines, maybe trans codes too. Call your local Autozone or big parts store and ask them.
SECTION 307-01: Automatic Transaxle/Transmission 2001 Escape Workshop Manual
DESCRIPTION AND OPERATION Transaxle Description The CD4E automatic transaxle is a four-speed, front wheel drive automatic transaxle with electronic controls for:
  • Electronic pressure control (EPC) solenoid for shift quality.
  • Shift scheduling.
  • 3-2 shift timing.
  • Coast braking.
  • Torque converter clutch control.
The transaxle features a four element torque converter with a torque clutch and a geartrain that includes:
  • Compound planetary gearset.
  • Chain drive.
  • Planetary gearset final drive.
  • Pinion and side gear differential.
The hydraulic control system of the transaxle has five solenoids that control:
  • Shift feel, through line pressure control.
  • Shift scheduling, through shift valve positioning control.
  • Modulated application of the torque converter clutch.
  • Timing of 3-2 shifts.
  • Engine braking during coast operation.
Solenoid Valve Body Assembly The solenoid valve body assembly contains the transmission fluid temperature sensor (TFT) sensor, as well as five PCM controlled output devices:
  • Electronic pressure control (EPC) solenoid.
  • Shift solenoid A (SSA).
  • Shift solenoid B (SSB).
  • 3-2 timing/coast clutch solenoid (3-2 T/CCS).
  • Torque converter clutch (TCC) solenoid.
You may need your PCM, Powertrain Control Module reflashed by a Ford Dealer.
Try disconnecting your battery for 1/2 hour and then reconnect and see what happens. It will run a little rough and shfit hard until it relearns your engine/trans characteristics.
Let us know results of tests and DTC codes if you get them.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
