My 1997 mazda 323 astina park brake light won't turn off, even when i have taken the handbrake totally off. I've noticed that after driving a while (20-30 km's) it will turn off, but i don't know what is triggering it to either stay on or turn off after so long
SOURCE: mazda astina pop up lights wont go back down
Try to check if there is something stuck to the motor of the pop-up lights mechanism. You can see it below the fenders. The fender liner should be removed.
SOURCE: Parking brake light remains on.
the parking brake light is the one on the dash so the switch by the foot pedal for the emergency brake is at fault
SOURCE: ABS, Traction control and handbrake
I have a Mazda Capella (626) 1998 and had similar problem other than it was running on 4 cylinders and the hand brake light was not on but speedometer was not functioning and the ABS light was on. The rear ABS senssor was the problem.
SDM
SOURCE: Knocking sound when driving over bumps on right
did you check our ball joints? jack up the wheel and try to move it side to side and up and down. it should move no more than an 1/8" either way. Any more than that and your ball joints aer starting to wear.
SOURCE: 1989 mazda astina 323 5 spd manual clutch fluid??
Check the brake fluid resovoir, on the side there could be a hose coming off it part way down the side sharing the brake fluid to the clutch master cylinder
